Thread: How often to run pump?
    Jul 2011
    Somerset, WI
    37
    I’m new to the pool ownership and not sure if this is the right forum but wondering how often I should run my pump in the summer? Lately outside air temps are about 80-95 degree mark here in Wisconsin. The pool has been in about a month and pump has been running steady the whole time. Pool temp right now is 85 degrees. Pool looks great and crystal clear but worried about $$costs running pump continuously. Can or should a person put a timer on? Will it re-prime ok if you do this, ok on pump?
    My equipment is:
    • 1hp pump (Pentair SuperFlo High performance)
    • Cartridge Filter (Pentair Clean & Clear CCP420)
    Thanks for you HELP!!
    29,700gal. (18x40, avg depth 5.5'), Cartridge Filter (Pentair Clean & Clear CCP420)
    IG, Vinyl, 1 HP Pump (Pentair SuperFlo High Performance), Pentair Master Temp 250
    Blink
    brett@blinkvisuals.com
    hawkeye's Avatar
    davenport,iowa
    118
    Re: How often to run pump?
    Yes hello welcome to tfp. We are here to help,Please post how many gallons or the size of your pool so we can narrow it down for you. Also if u need a good test kit check into Taylor K2006 kit or TF 100 kit. My pool is 8000 gallons and I run mine for 5-6 hours a day. Adding a timer is a great idea I have added one this year and love it.
    18ft 52in deep doughboy 8000 gallons
    22 in sand filter
    1 1/2 pump
    tk-2006 test kit that rocks!
    12.5% chlorine
    aqua critter vac
    30,408
    Great questions! Absolutely put your pump on a timer.....Lots of options.
    Reprime is a VERY excellent question. The answer is it certainly should but they do not always. Once you make your timer choice, see how it goes but be prepared to monitor it and find the leak if it drains back to the pool. For now, assume it won't.
    Depending on temperature and swimmer load, most of us seem to settle in around 8-12 hours daily. We usually start with about 12-14 daily and then gradually reduce that time as long as the pool is staying clear......mine is down to about 7 hours daily.
    Jul 2011
    Somerset, WI
    37
    Thanks Guys! This is a great site!! My pool is 29,700 gallons.
    So going off of about 12 hours a day is this best to run during the day with kids and the pool activities going or best done at night into the early am?
    One other thing I currently pull from my bottom drain and my (one) skimmer so it is setup 50-50. I have two jets at the end.
    Thanks again!!
    Blink
    30,408
    Most of us set the timers to run the time in 2, sometimes even 3, sessions split throughout the 24 hour period.
