Thread: Pump question for an AGP Intex 18'
    I want to redo the plumbing on my pool because it drives me nuts that none of the hoses are a standard size and parts are hard to come by in my neck of the woods. So my question is, would it be possible to use a sump pump as the pool pump. I would filter in a separate chamber before the water passed through the pump. I thought I would ask here before spending time and money for something that was doomed from the start.
    Thanks
    Maura
    22,550
    Re: Pump question for an AGP Intex 18'
    A sump pump is probably not going to provide good circulation. They're designed to move a lot of water but under low head conditions. You're better off looking at some of the Intex threads and what people have done with them.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Sump pumps typically have oil filled/encased motors. If/when the seal goes, it will then fill your pool with oil. Happened to one member here this summer already (sump pump on a home made solar coil). If you ever were to want to use one (solar coil perhaps) make sure the motor is not oil filled.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
