Thread: CYA loss
    Jun 2010
    Palm Harbor, FL
    18
    CYA loss
    I've done a bunch of searching but can't find an answer to this. Where does the CYA go???
    I test my own chlorine (fas/dpd) but rely on the pool store to test cya. When I notice my chlorine levels dropping I take a sample to the pool store and they tell me my cya is low. I assumed that cya was like salt, that overflow from rain and filter flushing is the only way to lose it. Is that true? Should my cya track my salt levels?
    In the last month, my cya has dropped from 80 to 25, but my salt has been stable at around 3000. Does the sun normally eat up some of the cya?
    As an aside, this forum and the info I learned have been a lifesaver. I no longer struggle with my pool. I was close to getting a dump truck full of dirt and filling it in Now, it is clear and beautiful all the time.
    11k gallon pebble tec pool
    goldline swg
    Hayward DE filter
    Mike M.
    10k gallon pebble-tec pool. Hayward DE3620 36 sq ft DE filter. 1hp pump. Goldline Aquarite SWCG with T15 cell. Aqua Cal heat pump.
    30,432
    Re: CYA loss
    Hi, Mike,
    Your comparison of salt and CYA is accurate. They should both be relatively stable in your pool. Splashout gets some and rainwater dilutes it.
    Like everything, there are some caveats but not applicable to you.
    Biggest likely problem?............Pool store testing.
    Get your own CYA test and you will KNOW what your CYA levels are rather than depending on the pool store results which tend to vary probably the widest on CYA.
    Apr 2011
    Lynchburg VA
    393
    Re: CYA loss
    IMO, the pool store loves you to have more CYA in your pool! The higher your CYA, the more chlorine you will by. My pool store told me my CYA was 30 and had me add more to the pool. When I found TFPs and got my own test kit, my CYA was around 200. The pool store printout I received says an acceptable CYA range is 30-300! Can you imagine the chlorine you would need with a CYA of 300? Might was well back up a truck and dump pit in!
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: CYA loss
    Quote Originally Posted by BadOleRoss
    Or imagine the amount of phosphate remover or algaecides that they would sell you to prevent algae growth!
    Apr 2009
    Burlington, ON, Canada
    344
    Re: CYA loss
    Yeah, get your own test kit. This past week, my pool store showed 30, my K2006 showed 55.
    A few weeks ago, same pool store showed 15, after I had put two kilograms of CYA in the pool. K2006 showed 60, another pool store showed 55. I told the first pool store manager they needed to calibrate their Waterlink Express (which is normally 'somewhat' reliable). Next time I went in to the pool store, they were still using the Waterlink, but at least they were testing the CYA manually. Still, the recent reading of 30 vs my 55 indicates something is still not right. I can only imagine the number of pool owners using that store that are now overstabilized.
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
