Results 1 to 14 of 14
Thread: Total Chlorine less than Free Chlorine ???
    Hello All,
    Yesterday I replaced my SWG and whilst I was at the shop I had my water tested. They used a automated precision pipette to measure water into individual test 'cells' that were pre-dosed with the testing chemical and sealed (obviously this seal was broken to add my pool water). Each 'cell' was then measured in a photometer. I would expect this to be as accurate as testing could be outside of a lab.
    the results were :-
    pH 7.4
    FC 2.89
    TC 2.08
    TA 90
    CH 170
    CYA 40
    Salt 4000
    This is for a SWG chlorinated pool and I would consider that the CH and CYA should be raised a little
    The thing that surprises me (and I dont understand) is how the TC is less than the FC? Surely TC=FC+CC and would always be slightly higher than FC ?
    Is this an indication of another problem, a testing error or perfectly normal?
    Thanks
    Tim
    21,000 gal.
    Sand Filter
    IG plaster/crystalcrete french gray
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: Total Chlorine less than Free Chlorine ???
    Not normal. A prime example of the error rate of such precise testing methods. Can't happen that way, the tester should have considered the whole set invalid when that occurs. The printout actually says this?
    edit: Not invalidating the test so much as the results. The method can be precise, the test can be valid, but when you get such a "blaring in the face invalid result" it throws everything off. That's why scientific testing has rules that prevent invalid results as countable.
    A CYA of 40 is the kind of number you get when doing the test yourself. I would have expected something like 39 or 41 before a solid 40. Just to prove it's accuracy. You do want to bring the CYA up to 60-80ppm for the SWG, if you trust this result. Try 10ppm at a time and see how the SWG reacts. Get your own test kit, then you'll actually know how your pool behaves if you change xx by xx quantity.
    Out of curiosity, was the FC and TC tested with two different samples in their own tubes, or did they test for FC and TC from the same pippetted (is that a word?) sample?
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Thanks for the reply frogabog,
    The results mostly match the tests I have at home (pH meter , Aquachek Yellow strips and Aquachek TruTest digital) in as far I they will test (only get FC and no CH with them).
    The shop tests were all individual tests samples and the only thing that concerned me was the TC. Maybe she swapped the TC and FC tests but, they were clearly labeled sample tubes and my FC tests all show the 2.8-3.1 sort of result (not the 2.0 result that I would expect if she had swapped TC and FC).Maybe the TC test wasnt given enough time to give a 'true' result.
    I have just added 1kg of StabiSel (granular cyanuric acid) which for my 42000liter pool i would expect to raise the CYA from 40 to 70. Hopefully that will be about right but will mean I need to use calhypo to shock instead of the stabilised stuff the shop says to use.
    21,000 gal.
    Sand Filter
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Or bleach. It's cheap and it works fine adding nothing but a trace amount of salt.
    Works great for many, most... nearly all of us.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    That's impossible.
    Let's go back to grade school, Venn Diagrams, sets and subsets, shall we?
    Is it possible for the number of boy students in a classroom to be greater than the total number of students in the same classroom? No. At most, the number can be the same, meaning, no girls. And so it is with chlorine.
    Free Chlorine + Combined Chlorine = Total Chlorine. The only way that test result is valid is if your Combined Chlorine is -.81. Impossible. Combined Chlorine can be no less than zero.
    Those testers look impressive, and probably sell a lot of chemicals, but they need calibration, and they can just plain be wrong, as you prove.
    30,419
    A perfectly normal expectation but, the more you read on the forum, the more you realize it's not true.
    Pool store testing is designed to LOOK precise and accurate. Unfortunately, operator error and some other factors make it quite a bit less reliable than doing YOUR OWN testing with drops based (seems sorta' old fashioned, doesn't it?) technology.
    It's really one of the eye-openers when you first find this forum. Naturally, one would assume the pool store people are the experts. However, with just a little bit of knowledge and the test kit to apply it, it turns out YOU are the single best expert on your own pool.
    Totally agree with what has been said
    The mere idea of TC being less than FC concerned me but, with my lack of experience I had to check that such a result wasn't a sign of something other than a testing error.
    I also agree with the norm being a lack of user ability in some stores and so was pleased to see a system that removed as much user error as possible. Shame that something managed to creep into the 'fool proof' system
    I am currently accepting all the results except the TC one as they match my own results.
    Many thanks for the replies and help.
    21,000 gal.
    Sand Filter
    Jul 2010
    England, UK
    156
    Doesn't the way TC is tested using DPD3 reagent in a photometer normally require a bit of time for the reaction to complete before the reading is taken? My test kit instructions say 2 minutes. If they didn't wait before taking the reading on the TC, then it could throw the result off.
    90k litres, outdoor in ground pool, concrete, painted (I hate paint)
    Sta-Rite 5P2R 1.5 Hp pump, undersized sand filter (needs upgrading).
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    The TC test in my Hanna meter also instructs to wait after mixing before running the test itself (pressing "read" button). 2 minutes 30 seconds. It also requires a clear sample to calibrate (zero) before every test no matter what it's testing for. Every sample is calibrated, then reagents/powders added, and finally the test is performed. FC can be tested immediately, as can PH, iron and hardness.
    FWIW... all my Hanna tests are consistent with my drop tests. As long as FC is below 2.5ppm and TC below 3.5ppm, of course. I do wish it was not limited so. Occasionally it's fun to get it out, spend two hours locating scissors, wipe off the glass test vials in case the eye gets confused, try not to tighten the cap too far and break it, attempt to pour all the powder out of the tiny foil packet w/o dropping any, run a calibration test for every sample, pause to prevent a kid from killing the other kid... find my way back to the meter... and run a nice precise test.
    Hmmm... Seriously, drops are so much simpler.
    I am convinced that the TC test was done too fast , the other tests concurring with my own.
    If I could get one , I would by a TF100 kit but they wont ship to the EU. Then I would have a full set of tests of my own.
    Discarding the TC result in the first post , would you all be happy with the other results (I have already added 1kg of CYA to raise it a little) or would the rather low Langelier Index concern you ?
    21,000 gal.
    Sand Filter
    Jul 2010
    England, UK
    156
    frogabog, you said "so long as FC is below 2.5ppm and TC below 3.5ppm" the tests are consistent. What sort of errors do you get above these values?
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Too high for the meter. It just doesn't test higher than that. It was purchased by my husband for his work with the intent to test potable water after sanitizing with mixed oxidants (like SWG). It didn't have to be the model that would test any higher than that. Most drinking water has less than 1ppm chlorine at the tap.
    The meter just happens to live at my house, H doesn't represent the manufacturer (Miox) anymore. Tis the way of mfr's representatives...
    frogabog,
    If you wanted to double the range of your tester you could :-
    1. Take water sample and mix it with distilled water 50/50 (a plastic syringe from your local pharmacy would do this accurately)
    2. Perform the test
    3. Double the result
    You could also triple or quadruple with the same method but , the intrinsic error of the way we test our water would also multiple as you diluted. Better than nothing though
    21,000 gal.
    Sand Filter
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Quote Originally Posted by TimboZero
    Unfortunately, better "fools" are created all the time!
    Love TFP? Become a
    TFP Supporter!
