Thread: Help with my pool !!!
    Jan 2008
    Dallas TX
    20
    I accidentally over filled my pool with water.
    I did it by forgetting the water on while I left the house for 3 hours.
    I then backwashed my DE filter and lowered the water to 1 inch below the skimmers max line (so the skimmers will actually be effective). Then I put my DE to normal (not backwash) amd I got tons of bubble going via my pipes and then some white thing that spread across my pool.
    I wonder what is this white thing ? Is it tiny bubbles? Is it DE powder ?
    For now what I did was to recharge the DE and I will run the filter all night long (now it is 8:30pm here).
    Any suggestions what I need to do in order to get rid of this white thing in my water ?
    My pools info:
    IG concrete pool, 15000G, DE, iRobot Verro, Located in DFW area.
    Guest
    call your local polterguist exterminator.
    ok im not sure but it may be a foam, are you guys still swimming??
    i remember late in the season of my pool that if we splashed enough we would create foam and the foam would leave a white resadue.
