Thread: How to clean pool filter hose of algae?
    I am desperately trying to clean to hose to the pump of algea, but I can't get it out. Every time I shocked the pool and also got rid of the alge I still have it stuck in the hose and of course that doesn't help preventing it from coming back.
    Any tips on how I can get it out of there? The water hose alone does not help.
    27' above-ground pool, Sta-Rite Diatomaceous Earth PLD-50 Filter @ 60 GPM
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: How to clean pool filter hose of algae?
    "What" exactly is stuck in "what"? Can you describe that a bit better. Are we talking about a vacuum hose to a skimmer?
    it's the actually hose from the pool filter to and from the pool. I have thick algea stuck in the rims and try to get it out. last time I shocked it it turned white, but I didn't get it ti wash and rinse out of the hose. now i took it of from the pool and try to get it clean, because it is already back green.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Did you shock the pool with a shock product or did you shock the pool according to the shocking information found here at TFP?
    What kind of pool and equipment do you have?
    You just responded above, so I'll address that now.
    The algae has re-bloomed and you're seeing it in the hoses because it is a good place for partially dead algae to hide. Re-bloomed algae means you haven't completed the shocking process because when that occurs and the water is maintained with chlorine levels appropriate for CYA level, algae can't hardly re-bloom like that.
    Do you have a test kit? What kind?
    The best way for us to help you is to post a full set of test results. A pool store can test your water if you don't have a kit but the best route to an algae free pool is to get your own. The TF100 at www.tftestkits.net is the best value around.
    Regardless, you will need to shock the pool again because if there's algae in the hoses, there will soon be visually apparent algae in the pool itself.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    22,553
    You need to shock till you pass the OCLT and then keep the FC at the high end of the recommended range for your CYA.
    ultra800_96's Avatar
    May 2009
    Pomeroy, Iowa
    225
    +1 what Bama said. If that is done properly, I think the hose situation will clear itself up.
    12,900 Gal. 24' X 48" ABG Vinyl Round (17th Birthday)
    1HP Hayward Pump w/S180T Hayward Sand Filter
    AquaTrol RJ SWCG 2011 startup
    TFP Method since '09, TF100
    50ppm Borates, June '12
