Thread: another leak posting
    vinyl liner pool, losing about 1/4 to 3/8" per 24 hrs.
    plugged the returns and skimmer, did the bucket test, still is losing water
    tried the food coloring at all returns, skimmer, steps and saw no place where the color was being sucked in. several of my return face plates are cracked but dont appear to drawing in the water.
    Pool pad is dry, except for when the heat pump runs ( condensation)
    Let me have it!
    17,000 gal inground
    vinyl
    swg
    3hp 8 returns
    heat siphon heat pump
    Western Pennsylvania
    151
    Re: another leak posting
    Do you have a main drain?
    Does the pool stop draining when it reaches a certain level?
    15ft round above ground pool (6600 gallons)
    Sand filter
    Jandy gas heater
    Intermatic timer
    hawkeye's Avatar
    davenport,iowa
    118
    Yes seems like you're losing water somehow.you really are the one who can only decided wether to get new liner or not. I would think you could find it if you look hard enough...check filter head control turn off filter spin it 360 to make sure it not hung up.is it possible you have a bad filter head and are losing water into to sewer return somehow? Not sure if you have a above or inground please post this info so we know what we are dealing with...
    18ft 52in deep doughboy 8000 gallons
    22 in sand filter
    1 1/2 pump
    tk-2006 test kit that rocks!
    12.5% chlorine
    aqua critter vac
    Quote Originally Posted by britinusa
    i have a main drain and i have not let it go to a certain level to see where it stops .. yet maybe in a month or so i will try that
    17,000 gal inground
    vinyl
    swg
    3hp 8 returns
