Thread: Limescale stuck on the bottom of the pool!
    Hi , i am new to the forum so i am sorry if i am posting in the wrong place.
    we seem to have limescale stuck on the bottom of our pool, we think its limescale rather than algea. It really is stuck and brushing it doesn't remove it. does anyone have any ideas on how we can remove it? the only thing i have been told so far is to drain the pool and clean it. but we have liner pool and you are not meant to drain them !
    Thank you for your help
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Limescale stuck on the bottom of the pool!
    Welcome to TFP!!
    This is a tough one!
    Acid should do the trick, but would harm the liner A rounded plastic scraper might do the trick, but again- could rip the liner
    I think your best bet is to adjust the pool chemistry so that, while it's safe to swim in, you'll dissolve the chunk.
    As such, can you please tell us your water chemical numbers? (cl, pH, Alkalinity, calcium hardness and CYA)
    Luv& Luk
    -Ted
    ultra800_96's Avatar
    May 2009
    Pomeroy, Iowa
    225
    Some friends of mine in town had that one spring on opening. I believe he took a broom handle (wood & smooth rounded end) & gently tapped on the chunks & they broke loose. I took him a while, for sure. As Waste also said, test results would be helpful.
    12,900 Gal. 24' X 48" ABG Vinyl Round (17th Birthday)
    1HP Hayward Pump w/S180T Hayward Sand Filter
    AquaTrol RJ SWCG 2011 startup
    TFP Method since '09, TF100
    50ppm Borates, June '12
    Hey man, just came accross this randomly on Google, but I have your solution!
    Viakal is what you're looking for.
    http://www.clickcleaning.co.uk/produ...10x500ml-.aspx
    Doesn't make much sense me typing out the big description, but basically, this stuff will dissolve the limescale and also create a barrier to stop it accumulating again. Also safe for use on ceramic tiles, which I'm guessing is what your pool is made of.
    Anyway enough product placement, I hope this helps!
    22000 gallon fiber glass Pool, 1HP Hayward pump , Sandfilter, Goldline T-15 SWG,
    Home brew coil Solar System http://builditsolar.com/Projects/Poo...ol_heating.htm,
    TF-100 test kit
    Jul 2010
    England, UK
    156
    Quote Originally Posted by PipBoy
    Not sure you'd want to add that stuff to a pool and then swim in it...
    90k litres, outdoor in ground pool, concrete, painted (I hate paint)
    Sta-Rite 5P2R 1.5 Hp pump, undersized sand filter (needs upgrading).
    30,432
    I would disregard that as a viable product.....particularly as it seems only available in the UK.
    Posting your test results will be the first step in solving your issue.
