Thread: CH on the Rise
    CH on the Rise
    So I did my full test tonight and got
    FC-6
    CC-0
    pH-7.2
    TA-80
    CH-450
    CYA-90
    My CH was 380 7 days ago..any idea on why it went up?? I added water yesterday but my tap water is only 150.
    14,000 gallon IG plaster pool, Cartridge Filter
    Re: CH on the Rise
    When water evaporates, all of the calcium is left behind. Then when you add more water to bring the pool back up to normal it brings along extra calcium, so the CH level goes up. Calcium is only lost when you backwash, splash out, overflow, or otherwise remove water from the pool.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: CH on the Rise
    What he said.
    On the other hand, it may not actually be that high....did you swirl it by hand or use a speedstir? My CH readings changed dramatically (for the better) when I let the speedstir really mix things up.
    CH on the Rise
    I have the speedstir...should I drain more water and refill
    Richard320's Avatar
    Jan 2010
    18,967
    Re: CH on the Rise
    Quote Originally Posted by thabeezer
    Your call.
    With careful attention to pH and TA, you can maintain CSI in the safe zone way up to about 800 CH. After that it gets very difficult - and I know this from personal experience. Your CYA is awful high, so it might not be a bad idea to drain off a few inches. Periodically I empty the spa into the pool and then use pool water to water the lawns while I refill the spa. Each time I do that, I exchange about 5%. It hasn't seemed to hurt the lawn any, but I do let FC run down to the low end of safe before hand. If you have a salt water pool, then I wouldn't use it on the lawn.
