Thread: Diving Board
    Aug 2010
    Bryant AR
    16
    Diving Board
    Seems to be coming loose from the base. How is this attached?
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Diving Board
    most styles use a board and a base. Remove the board by loosening the 2 bolts, this will let you access the bolts that connect the base to the deck. If they are loose, tighten them. Check to make sure there are lock washers on the bolts and you might want to use anti-seize on them as well. If the board or base are cracked they need to be replaced.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
