Thread: Broken pipes
    mcaron74's Avatar
    Jul 2011
    gardiner maine
    20
    Broken pipes
    I guess i dont even know where to start.....
    I just bought a house from forclosure with a 20x40 laxy l pool. I am in Maine and the pool is indoors. The pool room is 45x70 with radiant heat in the concrete floor around the pool. I have NO prior info on the house other than a pool company that says they installed it 25 years ago. The pool is 4/5ths drained, the return all have plugs in them and there are 2 over deck 2 inch pvc pipes going from the sand filter back into the pool(side by side). The pool company says they have not seen the pool in several years but believe the return lines have cracked, but the skimmers are good, that is why there are over deck return lines.
    Where do i start? I am already way over budget on repairs mooving into this house, I want to get the pool "fixed" ASAP so i can use it, but think i should look at the return line issue before i replace the liner?
    is this overdeck return line enough to properly circulate the watter?
    How do i check to see what is actualy broken, or where the breaks may be, with out watter in the pool?
    Is there a way to fix lines with out digging up concrete/radiant heating?
    I got a 4k quote on the liner and $500 for them to replace it... I believe i can get a liner online for $1800 and have seen u-tube videos and replacing it yourself doesnt look all that difacut? Is it worth the risk to try myself?
    Budget is a HUGE concern... any help or thoughts?
    I have read about the no dig- internal epoxy repair solutions, but there doesnt appear to be anyone in maine that can do a return watter line (1.5" I believe).
    I have not started this project yet as i am still moving in and fixing house plumbing issues. I would like to start working on this in the next 2 weeks.
    Thanks for any thoughts or advice!
    My Pool: Indoor 20x40 Lazy L, sand filter
    South Central NJ
    3,192
    Re: Broken pipes
    It might be possible to find the break(s) in the returns. A pipe inspection company may have a fiber optic camera snake with a sone that emits a tone that a sensor can pick up telling you where it is. If the camera shows you the break, depending on the type of break, the best course of action can be selected.
    This is what the pipe inspector would likely use:
    http://www.plumberscrib.com/Departments ... ating.aspx
    Scott
    Owner of - PoolGuyNJ LLC
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Broken pipes
    Welcome to TFP!!
    Where are you in Maine? (you can PM me your info) I'm in Sanford and, if you are close enough, I might be able to take a look at it.
    I honestly don't see a way to fix the pipes on an indoor pool without cutting into the deck
    However, let's take a look and see if it can't be done
    Luv& Luk
    -Ted
    mcaron74's Avatar
    Jul 2011
    gardiner maine
    20
    Re: Broken pipes
    I have attached 2 pics for those that are curious. Ide still appreciate anyone that has dealt with this type of thing before to answer my other questions:
    Can a home owner sucessfully replace a liner.. or is it better left to the pros? ($1800 vs $4500)
    Are the over board returns enought to circulate the pool or am i asking for trouble?
    If you look at the old pic with the pool full in the back right you can just make out the PVC dumping into the pool for the return lines
    Thanks
    [attachment=0:3qccrq2q]1003727_21.jpg[/attachment:3qccrq2q]
    [attachment=1:3qccrq2q]pool.jpg[/attachment:3qccrq2q]
    Mar 2007
    4,160
    Re: Broken pipes
    When there is no easy way to fix a broken pipe, you abandon it and run a temp line over the deck.
    How well it works depends on your pump and system.
    I'm more than willing to help you but, 80 miles is a rough 'quickie'
    Luv& Luk
    -Ted
