Thread: Intex saltwater swg testing questions
    I installed the swg wih sand filter last Sunday. I am using the supplied test strip the saltwater system came with.
    My free chlorine and Total Alkalinty appear to be fine. The ph is what I do not understand. The test strips start with a light orange color and number 6.5. The top number is 8.5 and more brownish orange. When I test my strip has a mostly red and little orange in the middle.
    Does this mean the ph is too high or two low? Do I add ph down or ph up?
    Also it looks like some more bronzish colored dirt on the floor. Is this bad? I used to just use chlorine and used shocked treatment. Should I ever shock the saltwater system?
    Thanks for any help.
    Gish
    Aug 2010
    Boston, MA
    176
    Re: Intex saltwater swg testing questions
    Test strips are useless. You need a real test kit (see the Pool School article Test Kits Compared). Pool store test results are better than nothing while the kit is on its way, and a full set of those would be useful.
    You may also want to read "How to Shock" to understand what that term really means (it's a process, not a product that you dump in once). The rest of Pool School is useful, too, but those two are the most immediately applicable.
    20k gallon IGP
    Plaster over gunite
    3/4 hp Hayward pump
    Purex Triton DE filter
    TF100 test kit w/ speedstir
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by blamman1
    My guess is your high, but you need a better test kit. See: http://www.troublefreepool.com/pool-...kit_comparison SWG tend to cause ph to rise more than using liquid chlorine.
    Is it sand/gritty? You could do a OCLT: http://www.troublefreepool.com/pool-...rnight_fc_test to see if you have excessive organics in the pool, but this really requires a better test kit.
    Its fine to use chlorine along with the swg. The swg will probably not be able to get your pool to shock levels. During shocking I would turn it off and just use chlorine.
    Make sure you read pool school (link on upper right of page), especially: http://www.troublefreepool.com/pool-...ary_pool_guide
    Thank you for the help
