Thread: Hayward S-200 filter problems--Please help!
    Had a problem with sand coming through jets and piling up in my pool. Also had a problem keeping water from turning green. We checked the laterals and found some appeared cracked so we replaced all ten. After vacuuming the pool, finally got it clear. We now have the same problem again with sand coming into the pool from the filter and it has turned green again (even though we kept a close eye on chemical levels). Obviously, the filter is not doing its job properly. Before I go out and buy a new filter, is this problem repairable? After looking at a drawing of the filter, could the problem be the bottom screen (looks like a lateral)?
    Any help you can provide will be much appreciated!
    Re: Hayward S-200 filter problems--Please help!
    Welcome to TFP!
    Sand getting into the pool and the water turning green are unrelated problems. Sand coming out of the filter is usually caused by cracked laterals, but can also be caused by other parts inside the filter being cracked or not fitting together tightly enough. The pool turning green is caused by in-appropriate chemical levels.
