Thread: Check Cell Light
    Check Cell Light
    I installed a all new system using a Hayward t-15 cell. I noticed today the the 'check cell" light is on. Chemistry is all okay and pool is clear as a bell. Any ideas before I dis-assemble the system to return it to store?
    22,553
    Re: Check Cell Light
    Did you unplug the cord and plug it back in?
    Oct 2010
    Georgia
    317
    If the inspect cell LED is flashing then there is no need to return the cell.
    The inspect cell light is only a service reminder.
    It is kind of like the oil change light on your car.
    Take a look inside the cell and look for calcium scaling.
    If you see scale, clean the cell per the manufacturers recommendations.
    If you don't see any scale, then put it all back together.
    To reset the inspect cell LED simply press and hold the black diagnostics button that is beside the LCD screen.
    The inspect cell LED should turn off.
    If the inspect cell is illuminated steady then the cell is no longer producing chlorine.
    PSG
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
