Results 1 to 13 of 13
Thread: Painting, re-sealing pool
    Aloha, it has been a little while since I last post. Too much fun in the water, year round!. Anyways, I have the pool that I made from a 20' x8'x8' deep shipping container, that needs to be refurbished. I have some minor leaks, so mostly the Poly Urea lining I used is starting to blister and the blue paint is chipping off. The container is steel and I plan to drain and tear off all the Poly Lining (RhinoLining) and repaint.
    OK what is the best way to line and waterproof the steel sides? Also is there any paint recommended that is somewhat more durable? The current topping above lasted 2 years. Ideas?? thanks
    Francis
    7800 Gal. 8' wide x 20' long x 7' deep
    Hayward 1200 Cartridge 7200 GPH, Waterworks 1/8 hp 2400 GPH
    Made from 20 Container Lined with "PolyUrea/Rhino Lining"
    Workshop, welding etc,+office+living area running off grid on 10kw PV
    South Central NJ
    3,192
    Re: Painting, re-sealing pool
    Is the inside surface corrugated or flat walled.floored?
    Scott
    Owner of - PoolGuyNJ LLC
    The sides are corrugated. The floor is wood and although I sprayed the plastic "bed-liner" everywhere, I suspect the floor will have issues especially where it meets the metal on the sides. 24 months in chlorinated water is bound to take its tole. Even the steel steps that were made from years old painted steel, the paint has flaked off and starting to rust! I am not opposed to having a liner made, but looking for something or method more durable than 24 months. I guess pools are like owning a boat in this maintenance respect.
    Francis
    South Central NJ
    3,192
    You read my mind but you need flat walls. I can't see a liner track following the ins and outs for the corrugated steel wall.
    1/2" or 5/8" marine grade plywood and a layer of wall foam would hold the pressure, allowing a liner. That would be go for about 10 years.
    Scott
    What about using something like FRP and overlapping edges and sealing edges with clear silicon? Or some other acrylic? I can weld tubing in the corrugated to help even it out. I also have paint that they use at Pearl Harbor shipyards for underwater marks on ships, but might be real toxic with a 5000 year 1/2 life
    francis
    South Central NJ
    3,192
    I don't know that the panels would resist flexing between the corrugations. If you can put marine grade pressure treated or steel studs between, it might work. How wide are the corrugations?
    Welding pipe in the spaces would still leave undulations though I don't know how much would be too much for the bead track, which still needs to be attached somehow.
    Scott
    I see issues trying to line the sides and think it might be better to use some heavy duty paint after ripping off the current "bed liner". What I really would like is to find some covering for the bottom. Even a few inches of a concrete-type material. This would seal the bottom and hopefully protect the wood floor from eventually rotting with the water eventually seeping in .
    What type of material would work as we do not have temp extreems here in Hawaii and the water is never drained.
    thanks
    Francis
    Anyone got any ideas about this?
    Francis
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    There are companies that resurface pools with a new fiberglass liner, for instance fiberglass over gunite. I learned about this idea from a piece of junk mail from the company that does this in my area. I've got no idea how well this works or if it could be a DIY job.
    Here's a link to a similar company I found by googling for "swimming pool +fiberglass liner": http://www.fiberglasspecialist.com/index.htm .
    Good luck!
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    South Central NJ
    3,192
    I can guarantee F/G would delaminate and blister. It also needs periodic painting.
    Scott
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Quote Originally Posted by PoolGuyNJ
    Scott
    He's got a Conex box with Rhinoliner that lasted for 2 years for a pool. F/G that delaminates, blisters, & needs to be painted sometimes? How much worse can that be?
    TF-100 test kit.
    South Central NJ
    3,192
    Let see, $75/gallon for paint(or more due to location), $50 for painting supplies, having to scrub chalkiness between corrugations every week, F/G repairs at $100/hr for several hours plus materials every couple years, drains and refills,
    vs
    Get the wall paneled, add a liner bead and liner, replace every 10 years or so. Normal pool care.
    Scott
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    +1
    That seems like a pretty simple solution. Adding the panels would be much like putting sheet rock on a metal stud wall.
    TF-100 test kit.
