Help with My Super Pump
Jun 12, 2011
41
Michigan
Newbie here, I just had my pool installed and today the electrician came and wired everything for me. I did all of the pvc piping. When I started my super pump, it seems to run hot and I get air bubbles coming out of the return line, everything I read seems to indicate it this is caused by air leaking in the suction lines, but it seems like I have good tight joints, any thoughts? My pump is about 30 feet away from the pool.
it is a pretty simple design, it just has a skimmer and a return. I did not shut off the skimmer,afraid that i would have no water flow through the pump. Although the water level is about 3/4 of the way up the skimmer so I don't think I am getting air in there.
Ok I am about to loose my mind. I checked all of the connections can't find any leaks, I had the electrician come back, he said everything is wired correctly, he said he thinks it is a bad pump. I get no pressure, and the pump runs hot, if I let run for more than a few minutes it will shut down.
yes I was finally able to prime it, so the basket is full of water, but the pressure is really low on the filter. It feels like there is a good flow of water going back into the pool but the strainer does not seem to empty that quick.
Ok so this is exactly what is happening, I have had the electricians out twice now and they are saying it is not an electrical issue but that the pump is bad, but this is what they hayward site is saying about my exact symptoms.
Why is my pump running hot and powering off?
This maybe caused by insufficient power due to an undersized wire or a poor connection. Check your owner’s manual for proper wiring.
Your local power company might be experiencing a power drop especially during a heat wave. Restart your pump when the weather cools to confirm that the problem is really in the motor.
Your pump has a thermal overload, which will shut the motor off when it gets too hot—it will restart once it has cooled down. Check the air intake vents of your motor to ensure they are free of debris. If debris is blocking these vents, it will cause the motor to run hot and possibly shut down.
Make sure your pump is located in an area with adequate drainage. Flooding from rain and other sources could cause a pump to run hot and cut off.
Pressure is very low like 2. I know when he was wiring it, he asked to see the owners manual to help him figure out how to wire it to 110. I had the second electrician from the same company check it, he said it was wired for 110. Also, they used a 12 guage wire but it runs about 70 feet from my box, on the hayward manual, it shows the runs going up to 50 feet.
Abbysdad - we really need to know how big of pump you're using.
It was pointed out in another thread that watts are watts - whether you are using 120V or 240V. Where the difference is is in the size of the wires needed because of the different amps. 12 guage wires are probably adequate - for a steady state load of 16 amps or less. Any larger - and you should be using 10 guage, and if your run is long enough / high enough - you may even need to use 8 guage.
