Thread: Free Chlorine will not hold
    I am having some difficuly in holding a measurable chlorine level. reecntly i added a stain remover which required me to run my chlorine down to 0. Since then i have attempted to bring my chlorine back to normal levels and have been unsuccessful. PH, CYA, Alkalinity, Hardness are all at the recommended levels. i have added shock and the chlorine still does not hold. Any advice?
    22,550
    Re: Free Chlorine will not hold
    Who's recommended levels?
    We like numbers:
    pH
    FC
    CC
    TA
    CH
    CYA
    Clarity of your water?
    We also need to know pool size and type.
    How do you normally chlorinate?
    Since you had zero chlorine for a while you're going to have to shock, and shock is a process not a product. You'll have to hold it at shock until you pass the OCLT. You'll also need a good test kit to tell you that.
    thank you for the support. the process of shock is what finally allowed the free chlorine to hold.
