Thread: Good ole Monsoon
    Jul 2008
    Queen Creek, AZ
    71
    Good ole Monsoon
    I had a fantastic last year using the BBB method for my pool. For some reason, this year has been a nightmare. My PH goes of the charts and I have to use MA to lower it all the time, and now, for some strange reason, we are having a very bad Monsoon season. My pool was going down 2-2.5 every day all summer until last week. It started to go down 4ppm a day. I can't find my CC test but knew something was off. So I decided to shock my pool which is something I haven't done since using the BBB method. Pool has been vacuumed and scrubbed down. The pool calculator recommended 19 and did that last night. I just tested again and its down to 8, What is going on ! The bizarre thing is, my pool still looks great. BTW, I live in Phoenix AZ.
    FC -8
    CC- ?
    PH 7.8
    TA 90
    CH 250
    CYA 65
    Borate 50
    water temp at 90
    Pool size 10,000 AG
    Pebble Tec
    Jandy Cartridge Filter
    Build in 2008
    Waterfall, pop ups
    22,553
    Re: Good ole Monsoon
    How much water have you had to drain from the pool?
    What size is your pool?
    It'd be good to run the OCLT.
    Jul 2008
    Queen Creek, AZ
    71
    pool is 10300 gallons. We drained 80% of the pool last year. I'll try the OCLT tonight see where it goes. Thanks
    Pool size 10,000 AG
    Pebble Tec
    Build in 2008
    Waterfall, pop ups
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by gsmiley
    Do you have the tf100 or taylor 2006 kit? Testing for CC is easy with those and important if you are fighting something organic. Both use the R-0003 reagent, after doing the FC test (but before dumping it out), put 5 drops of the R-0003 reagent in, and repeat drops R-0871 titrant. This will give you CC.
    Jul 2008
    Queen Creek, AZ
    71
    Quote Originally Posted by linen
    I have the tf100 and for some reason can't find the CC (r-0003). I plan on going to our local leslie pool which sells the product by bottle.
    Pool size 10,000 AG
    Pebble Tec
    Build in 2008
    Waterfall, pop ups
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Ahhh...sorry about that, good idea to get it!
