Thread: Just checking: is 1.5 FC loss every day normal?
    surfhawaii's Avatar
    May 2011
    Kailua, Hawaii
    63
    For 2 months now (since joining this forum) I've been following your lead and am happy that chemical balance has been under control and not one day of cloudy water (something that I always struggled with when I had pool guys do it). Water is crystal clear and I get all kinds of compliments from visitors - thank you very much.
    I seem to lose about 1.5 ppm of FC every day. CYA is ~35-40 (still have trouble reading this) and other tests are within TFP recommended levels. I really don't mind adding bleach every few days but am curious, is this normal? As you might guess we get a lot of sun here. Should I raise the CYA to 50 ppm...would that help?
    Thanks again, I recommended you guys as life savers to a friend the other day.
    22k gallon, Sand filter (Triton II TR 100)
    IG tile
    Pentair VS pump
    SWG
    Sundance Chelsee spa
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Just checking: is 1.5 FC loss every day normal?
    1.5ppm would be on the low side for normal loss. You are doing well.
    22,550
    If you're just losing 1.5 ppm per day, I wouldn't change a thing.
    the only way I can get down to 1.5 is with the solar cover on. On these hot days with a 105+ heat index I've been losing around 5ppm, but that's also partly because my CYA is 90ish. I try to keep it above 11.5-12, which means I'm taking it up at 17 at night and it's around 12 the next night.
    add the fountain running 8-12hrs per day to cool the water and it ends up being 5.5ppm/day loss.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
