Thread: What does thing mean, please see pics
    I am sorry for asking beginners question, but please bear with me, I just moved in last weekend, and there are so many things going on, so I am looking for a quick help, I am attaching pics of my pool pump, please explain me what does each things means, really appreciate it.
    11000 Gallons, Cartridge Filter, UG, Plaster, Shasta pool, filter model Hayward C4030, Pump Motor Emerson 1-1/2HP Full Rated EB2977T, Pump model Northstar SP4010NS
    South Central NJ
    3,192
    Re: What does thing mean, please see pics
    Quick Skim appears to be a venturi based skimming system. Returning water is sent to the skimmer for a somewhat faster skimming action.
    Aerator is a return that breaks the pool surface, reduces the alkalinity level and results in the pH rising.
    Cleaning System is part of Paramount Floor cleaning system. This houses a return water turbine driving a gear box operated set of valves inside it that sends water to different sets of pop up floor jets that direct water along the floor and any debris there towards the bottom drain for collection in the Leaf Vac's basket.
    Main Drain is at the bottom, typically in the deepest section.
    Skimmer is the rectangular opening at the water line to suck in debris that hasn't broken the surface tension of the water in the pool.
    You have a Hayward Northstar series pump and a Hayward cartridge filter though it appears to have been rebranded, probably from Leslie's Pools.
    Scott
    Owner of - PoolGuyNJ LLC
