Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Clarification on pool startup
    After battling with the stock 700gph pump, I broke down and bought the Intex 1600gph sand filter pump. Since the old pump has been out of commission, the algae got out of hand before I learned what to do about it. To simplify and speed things up, decided to drain and clean the pool and then refill.
    It's nearly empty now. Going to scrub it down good and rinse it out, then start filling it back up tomorrow.
    I have the new pump, 50 pounds of filter sand, the SWG, and 90 pounds of sand.
    I've been reading the forum and Pool School for the last few days, but am still uncertain how to approach this.
    Once the pool is full, should I pour in all the salt in and then wait a day or two before firing up the SWG?
    Or should I add the CYA and some bleach first to get the chlorine going first?
    Would like to get it going ASAP, but also want to learn the right way to get the pool going since we'll be doing it again in the spring.
    jakeinga
    • Central Georgia
      14' x 42" Summer Escapes frame set(3750 gallons)
      Intex SWG
      Intex 1600gph Krystal Clear sand filter pump
      2 kids ready to jump in already
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Clarification on pool startup
    Quote Originally Posted by jakeinga
    After battling with the stock 700gph pump, I broke down and bought the Intex 1600gph sand filter pump This is a much much better pump an filter, you will love it. Since the old pump has been out of commission, the algae got out of hand before I learned what to do about it. To simplify and speed things up, decided to drain and clean the pool and then refill.
    I have the new pump, 50 pounds of filter sand, the SWG, and 90 pounds of sand.I assume you mean salt
    I've been reading the forum and Pool School for the last few days, but am still uncertain how to approach this.We will help. Best place to start is: http://www.troublefreepool.com/pool-...ary_pool_guide
    Once the pool is full, should I pour in all the salt in and then wait a day or two before firing up the SWG? Yes, wait until it goes into solution. Swimmers help alot, brushing too, and pumping 24/7.
    Or should I add the CYA and some bleach first to get the chlorine going first? Yes and yes, read the link above.
    jakeinga
    Yep, I meant 90 pounds of salt.
    So you're saying I should add CYA and bleach before dumping the salt in? Nothing I've read is really clear on that.
    If that's the case, then I would have to wait around a week before turning the SWG, right? Since the CYA takes a while to dissolve?
    • Central Georgia
      Intex SWG
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    To start with you can chlorinate your pool with bleach until the salt goes into solution (crystals disappear in pool water). It takes my pool 24-48 hours for the salt to dissolve. Meanwhile you want to have FC (free chlorine) in your pool to avoid organics. You will be adding chlorine every day until you turn on the swg, then the swg will take over maintain normal levels of chlorine in your pool.
    Step 3 of the link I mentioned above suggests starting with 6 ppm of FC in your pool.
    Step 5 discusses how to add CYA using the dichlor method. If you do not already have dichlor, I recommend using granular stabilizer (ingredents should be ~99% Cyanuric Acid) put in a sock and hung by the pool return. It will take a few days to dissolve. Use the poolcalculator.com for all calculations including how much cyanuric acid to put in your pool.
    Get a good test kit, it will save you money and time in the long run! See: http://www.troublefreepool.com/pool-...kit_comparison
    Let us know if you have questions!
    22,553
    Adding to what Linen said, We recommend waiting 24 hours after adding salt to turn the swg on. You don't have to wait till the CYA dissolves. While you're waiting you want to chlorinate with bleach so things won't start growing. After 24 hours turn the swg on and test and adjust as required. You can suppliment with bleach if you test too low.
    Now I think I'm on the right path.
    Thank y'all very much for clearing that up.
    • Central Georgia
      Intex SWG
    I filled an old sock with the CYA and tied it off to the bottom of the ladder.
    Then added bleach to the pool for the first couple evenings.
    It doesn't look like the CYA is dissolving very well. Put it in three days ago. Isn't it supposed to be totally dissolved after a week or so?
    • Central Georgia
      Intex SWG
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I would put the sock by the return, so it gets buffeted by the flow. You can also squeeze it whenever you are out by the pool. If the CYA sock is left undisturbed, it can take much longer to go into solution.
    I'll have to try that, thanks!
    • Central Georgia
      Intex SWG
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Squish squish... What brand did you use?
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Not sure what the brand is, it was the only stabilizer I could find at Wal-Mart.
    We don't have a pool shop in town, and Ace didn't have any in stock.
    • Central Georgia
      Intex SWG
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Walmart brand is fine, that's what I usually use. It seems to disolve fairly quick if you squish it, but it still may take up to a week to fully register in your water.
    24 x 52 Round AG Outback Empire Pool 13,500 gal.
    1 HP Hayward Power-Flo pump w/Hayward 18" 150lb. sand filter
    TF-100 test kit & SpeedStir
    Wanda the Whale Vacuum
    I climbed down the ladder this morning and squished it around a bit.
    Seems like it got knocked around pretty well yesterday, as it's all nearly gone now.
    So once it's totally gone I should be able to get a fairly accurate reading on the CYA, right?
    Until I'm able to get a TF kit, I'll have to take my water to ACE and have it tested. I bought the 6-way strips at Wal-Mart, but don't really trust them.
    • Central Georgia
      Intex SWG
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I would wait a few days to test (maybe a week), since some of it is probably still hanging around your pool bottom. It is not uncommon for CYA readings to take a week to stabilize after it is in the pool. Also, if you do not need too, I would not backwash the filter.
    Uuuuhhh...so then I guess it wasn't a good idea to test out the vacuum yesterday.
    • Central Georgia
      Intex SWG
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    If you vacuumed to waste...probably not...wait a few days, then test. If you need more, add it then.
    I didn't put it on waste, just the normal filter setting.
    So I guess it's all in the filter now.
    • Central Georgia
      Intex SWG
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Your good then, just don't backflush for a week (maybe less since I would think the CYA would go into solution faster being in the filter and seeing flow/disturbance all of the time).
    Hey linen, I notice in your sig that you have removed the copper bars from your SWG.
    Why is that?
    • Central Georgia
      Intex SWG
  20. Back To Top    #20
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    To keep copper out of the pool...always a very good idea. Copper can stain the pool and turn blond hair green (used to happen to me in a pool when I was taking a lifeguard training instructor course). Removing the copper bars was probably an overreaction on my part. I could have just unplugged them so the system wouldn't produce the the copper ions, but I didn't want any copper in my pool. Copper ions for an "algaecide" are not needed when a pool is properly chlorinated and maintained.
