Thread: Salt Testing
    Salt Testing
    I took a test using the taylor drop test and it came out at 2900ppm. The SWG is reporting 3300ppm. I know the philosophy is always trust your numbers, but my understanding is there is potentially a 400ppm swing in the test. I am just trying to figure out where to go from here. Any input would be much appreciated.
    18x36 29K gal Gunite - 1 HP Hayward Super Pump
    Hayward Aqua Rite - 40k Cell - 24" Hayward Pro Sand Filter
    Polaris 380 w/ booster - RayPak 336K BTU Propane Heater
    Twitter: @jfgreco
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Salt Testing
    Split the difference? 3100? You're in the ballpark. I believe your unit needs between 2700-3400 PPM so you're good to go. Any fault indicators?
    Re: Salt Testing
    You are good. There is no reason to worry about the exact number, it is clearly in the right general range.
    Re: Salt Testing
    Your responses are much appreciated. The reason I worry, is that I travel frequently in the summer and don't want to come home to a green pool. Still trying to learn the ways of the SWG, but I have to say since installing it and learning about TFP, it truly has been a trouble free summer! No real issues, and it has been great!
    Twitter: @jfgreco
