Results 1 to 9 of 9
Thread: Help me ID this skimmer and what satellite valve I need
    Hello all! After reading on this forum what I need to do to activate my MD I went to the local pool place and picked up a satellite valve. I went back to the pool all excited only to drop it in and note it sits crooked. There is the pump hole, the hole to the MD and then this cap looking thing that sticks up and prevents the satellite from seating. The hole with the larger recess is to the MD and the other goes to the pump. Any help you can give to get this MD working is much appriciated! If it helps, the permits I found said this pool was installed back in 1973
    Thanks!
    Andrew
    31' x 13.5' in ground Bella Blue Pebble Fina ~15,000 gallons
    pump STA-RITE #p6e6d-205l
    filter sand Triton II model TR-60
    A clear pool thanks to BBB
    22,553
    Re: Help me ID this skimmer and what satellite valve I need
    Look on the cover and around the skimmer. There should be markings on it somewhere. That will give us an idea of who made it and therefore the proper parts for it.
    Hello, I just went out and looked all over it and could not find any numbers or words of any kind on anything. The lid is a sta-rite but can't be original, it has 2 screw holes, and the skimmer has 3 holes.
    Andrew
    22,553
    maybe some of the other guys will be able to tell what it is.
    So, no one knows? Please?? lol I tried a few online places and they don't know. And have taken the picture to a couple local places and they don't know. I'm about to start pulling over the pool people I see driving down the street and ask them. :-\
    Andrew
    Dec 2010
    San Diego, CA
    1,137
    Did you get this figured out during your remodel? Can you remove the cap thing that bumps up? It looks like there is a screw hole there?
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    No we didn't. We just decided to block off the main drain, install a dedicated vacuum line for the sand shark and let the skimmer be a skimmer.
    Dec 2010
    San Diego, CA
    1,137
    Did you remove the main drain itself too? I'll have to go check your other thread
    Yes. The main drain was deleted- plugged and covered over.
