Thread: Thanks. It works!
    Jul 2011
    Stockton, CA
    63
    Thanks. It works!
    Thanks to all who responded to my frantic posts over the last few weeks because of unmeasurable FC despite clear water, and CYA of 80-100. I was a skeptic, but after shocking for several days with gallons of bleach, I now have clear water, no slime, no algae. FC in the AM is 7-8, with OCLT of 0-1, and CC 0-0.5. My evening FC is 3.5-4. I am adding bleach every evening, based on numbers from the pool calculator, with a CYA of (probably) 35. The dosing is extremely accurate.
    The big unknown is CYA. I use the TF-100 kit. After a 60% pool refill, I got CYA 30-35. My friendly local pool supplier got 60! I took a sample to Leslie's. The girl used a test trip and told me "0". I insisted she use a drop test. She then used a Rainbow kit with the black dot that pulls up on a little stick, and is read when the dot appears, rather than disappears. After multiple reads by her and me, we agreed on 35!
    So, be very careful about who to believe on CYA tests; probably best to trust yourself! This is a highly subjective test, even when following Taylor Chemical instructions, or the extended instructions on this site. For me, the minimal and target FC levels are not much affected by CYA between 30-40, so I'm satisfied.
    Thanks again. No one in my local pool community had any idea whatsoever on why I could not measure chlorine. Thank goodness for Google and TFP.
    22,500 gal, in-ground, plaster, Intelliflo VS 3050 pump, Sta-Rite 400 sq. ft. cartridge filter, solar panels on roof
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Re: Thanks. It works!
    SEE, we KNEW you could do it!
    24 x 52 Round AG Outback Empire Pool 13,500 gal.
    1 HP Hayward Power-Flo pump w/Hayward 18" 150lb. sand filter
    TF-100 test kit & SpeedStir
    Wanda the Whale Vacuum
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Yay!
    Now stick around and encourage the next pool store victim who stumbles across this site.
    Jul 2011
    Stockton, CA
    63
    Quote Originally Posted by Richard320
    Yay!
    I NEVER would have believed the amount of chlorine that might be required to solve the problem, or the frequency of testing/shocking. But, I'm a believer.
    A couple parting shots:
    I will try to never add anything to the pool that requires draining/replacing water to fix.
    I think I like the black dot on a stick method better for CYA testing. For me, it was much easier to see the "appearance" of the black dot, rather than its "disappearance".
    A suggestions where to get that type of tester?
