Thread: Filter pressure..
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Filter pressure..
    Hi all. I have a question. I went out to add chlorine and tighten up a small leak and noticed my pressure gauge is only reading about 4, it usually reads about 16. So, I walked up on the deck and the water flow coming out of the return is perfectly normal. Is this a broken gauge or possibly something more? The guage is original to the pool, so I'm guessing around 4 0r 5 yrs?
    24 x 52 Round AG Outback Empire Pool 13,500 gal.
    1 HP Hayward Power-Flo pump w/Hayward 18" 150lb. sand filter
    TF-100 test kit & SpeedStir
    Wanda the Whale Vacuum
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Filter pressure..
    Odds are good it's a bad gauge. They fail often, but fortunately are cheap and easy to replace.
