Thread: Chlorine Output
    Chlorine Output
    Is there a conversion that takes the amount of lbs of chlorine a SWG makes and turns it into chlorine amt in gals (based on %)
    Example, my pool uses .5 gal of 10.5% chlorine, How much lbs of Chlorine does my SWG has to produce. I am seeing comparisons of SWG rated for 30,000gal and they range from .7 lbs to 1.2 lbs of chlorine.
    Does a SWG produce 100% Chlorine so I need 10% of the volume based on 10% chlorine? If a gal of Chlorine weighs 9lbs does that mean I need .9lbs of chlorine?
    I understand that the SWG has % to compensate but I also see alot of TFP'er running their units at 70 - 80%.
    20x40 24,000 gal IG plaster/CircuPool RJ45 SWG/2 skimmer/2sp 2.5hp Jandy Stealth/340sq ft cart filter/600sqftHeliocol Solar Panels/6ft semi circlr tanning ledge/25ft deep end bench/5ft sheer descent/2 lion head water features/1300sqft travertine paver/2 Colorlogic lights/Hayward Navigator/3step 2ft raised bond beam
    Re: Chlorine Output
    You can do conversions with the Pool Calculator and a tiny bit of math. SWGs are normally rated in the weight of the equivalent amount of chlorine gas they can produce running at 100% for 24 hours. Scale that down based on your pump run time and percentage setting and enter that in the Effects of adding chemical section towards the bottom with the popup set to chlorine gas. That will give you ppm of chlorine for your pool. You can then enter that in the FC section to see how much bleach/liquid chlorine that is equivalent to.
    Jul 2007
    Brisbane, Australia
    874
    Re: Chlorine Output
    you can find the calculator in my signature that kind of does the opposite, converts bleach into suitable chlorine output
