Results 1 to 8 of 8
Thread: Where can I order wrought iron fence panels from?
    Sarnia, Ontario Canada
    162
    Or wrought iron looking... King architectural has a few options, but many are "for the trades only".
    But I can measure, level and set posts, and fitting drilling and fastening the panels is well within my capabilities. Let me know if you have come across a
    Website.
    Thanks!
    Ps. My local code requires 5' fencing....
    20x47' double roman vinyl liner pool. Pentair EasyTouch 8PSC-IC40, 011018 Pentair IntelliFlo, Pentair Clean & Clear Plus Filter CCP420, Pentair 120V IntelliBrite LED, Cleardeck indeck solar reel, 530 sq' solar system Polaris 9300xi robot, Interfab Turbotwister slide, S.R. Smith T7 diving board, deck jets vinyl-liner-pool-build-in-ontario-canada-new-pictures-t30213.html
    Sep 2010
    Noblesville, IN
    104
    Re: Where can I order wrought iron fence panels from?
    16 x 32 15300 gal. IG Vinyl Jandy pump, Jandy sand filter, Paramount circulation system, Automatic pool cover.
    Jan 2011
    Riverside, CA
    352
    I installed some AmeriStar Aluminum fencing a couple years ago. Nice, strong (way stronger than the suff at HD and Lowes), and powder coated. The fence has a Limited Lifetime warranty. A little expensive, I think my Echelon Plus panels and posts were about $25-$28 a LF for just the materials.
    http://www.ameristarfence.com/
    I found a local shop that placed the order for me. It is a very nice fence and easy to install (the panels are attached to the poles with brackets). My panels came assembled, but I think you can also order them unassembled (you install the individual pickets into the top and bottom rails). I had to cut several of my panels, it would be a piece of cake to put them together.
    There are a couple other companies that make fencing like this:
    http://www.masterhalco.com/
    40x20 Free Form IG Pool (aprox 29,000 Gal, 140 Perimeter, depth 3'6"-7', Baja Shelf, 8x8 Free Form Spa) - Gunite Shell, Pebble Plaster Finish, Poured Concrete Coping - 3 Deep Heat Returns - Jandy LXi400 Gas Heater (400,000 Btu) - Jandy Variable Speed Pump JEP 2.0 - Jandy CL 600 Filter - HASA Liquidator - Jandy PDA 6 w/ Remote - 4x Jandy WaterColors Pool LEDs - 48" Gas Fire Pit - 6x Gas Tiki Torches - 12'x15' U-shaped BBQ Island (Firemagic Equipment)
    http://www.troublefreepool.com/new-p...ca-t28413.html
    Green1340's Avatar
    May 2011
    Kemp, TX- 50 mi. south of Dallas
    55
    I found the least expensive panels on craigslist. Not sure if that is available north of the border.
    Greenhaw
    Freeform Gunite, 21K Gallons, Gray Plaster, 570 sq. ft., 106 Perimeter.
    Pentair- VS 3050, Intellichlor IC-40, 520 sq. ft Cartridge Filter, Intellibrite LED.
    Sun Touch Controller, Legend Platinum Cleaner with Pentair 1.5 hp Booster Pump.
    2- Bubblers & 2- Deck Jets. Autofill & Overflow. TF-100-Test Kit.
    SW Georgia
    300
    I bought mind from http://www.discountfence.com. Ornamental fencing by Jerith. As far as my research goes they were the cheapest but that was three years ago. I got great customer support and some very useful tips from there salesperson. The main tip that I felt was the most important was not to purchase a fence that the pickets extended below the bottom rail. These will get bumped by the lawn mower and bent and will eventually break. The only problem I had was that UPS damaged two panels during shipping. Definately plan to be home for the delivery and look over each piece. Make sure you document any issues on the packing slip clearly and read all the requirements that have to be meet in order to have a valid claim before signing for the damaged goods.
    35K IG Vinyl 20 x 40 self built pool, Hayward Pro Series High-Rate Sand Filter 31" 98gal/min, Hayward TriStar 1.85hp, Hayward 400btu heater, BBB method w/Hypo, Jazz light w/matching fiber optic rope lighting around coping w/syncronized color wheels. Concrete Paver deck.
    Jan 2011
    Riverside, CA
    352
    Jerith was another one I looked at for my yard.
    I also wanted the 'smooth' top and bottom rail. I found this photo I took before I leveled everything out and cut off the posts.
    Look, my tree just fell over...
    162
    thanks guys!!! I'll definitely check these out
    Dec 2010
    Central California
    15
    I just installed Ultra aluminum fencing around my pool area.....http://www.ultrafence.com/fencing.html
    There're several vendors....I went with http://www.aluminumfencespecialists.com/.
    The customer support is great. Highly recommend them.
    30'x14' (12.5K Gallon) Viking Carmel - Saphire Blue Crystite Finish
    Jandy Stealth Pump - 2 Speed 1.0 HP
    Jandy Cartridge Filter - 340 sq. ft.
    Fiberstars 6004 Metal Halide Light with 4-Position Color Wheel
    Polaris 280
    Maintained with BBB
