Results 1 to 14 of 14
Thread: am i infested?
    May 2011
    Orillia, ontario, canada
    50
    am i infested?
    Everyday i have to clean the pool and get rid of all these bugs:
    I also have i think sand at the bottom of the pool that i can't seem to get rid of....
    Is this normal? if i hit it with the pole / foot, it dusts up and disappears. I'm guessing it's sand.
    I do have a sand filter. I'm guessing it needs some TLC?
    My neighbour has a large maple tree that very close to my pool.
    What do you guys think?
    Approx 74,000 liter inground vinyl pool 12x32, laser 225 sand filter, Hayward 2 speed pump + old pool heater.
    Aug 2010
    Dallas, TX
    4,052
    Re: am i infested?
    Are you positive it's sand from the filter though? Can you touch it and see if it's gritty? Pool filter sand is very gritty.
    22,539
    Re: am i infested?
    Wow, you have as many bugs as we do. Most of ours are ants and small bees though.
    You can run the OCLT to be sure but it just looks like dirt to me.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: am i infested?
    It will help if you post a full set of test results:
    FC
    CC
    pH
    TA
    CYA
    CH
    When you touch the stuff, does it geel slimy, gritty, squishy?
    You're done SLAMing when:
    May 2011
    50
    Re: am i infested?
    Fc 3
    Ph 7.7
    Ta 170
    Cya 25 ish... I had to fill the entire Taylor test tube to not see the black dot.
    Pool temp average 28
    Ch 130
    tested on Sat
    I just tested last night for FC.. it was 3.0 last night and this morning was 2.5
    ph was 7.8 - 7.9
    the brown stuff that's on the seams feels gritty/slimy.. i'll have another feel tonight.
    I just moved into the house last weekend, so i'm not sure when or if the filter on the sand filter has been changed.
    Aug 2010
    Dallas, TX
    4,052
    Re: am i infested?
    Sand rarely if ever needs to be changed in my opinion, despite what the pool store says (5 year life).
    May 2011
    50
    Re: am i infested?
    hmm i have to figure out how to do CC vs FC with this taylor 2005 test kit....
    i added the power, then added r0003 i believe... and i thought that was FC..
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: am i infested?
    Do you have a working skimmer? If so, do you see surface debris flowing into it?
    I can't really help on the bugs, we're relatively bug free here and most of the ones that do land in the pool go right into the skimmer. But I see a lot of grass in your images and wanted to suggest placing a foot bath at the ladder and instruct swimmers to rinse their feet before climbing into the pool. At least part of your debris problem will be solved this way.
    If you have kids with broken listeners who routinely step over the foot bath, let me know. I've employed a dictatorship footbath solution that solved the broken listener problem around our pool. This whole season I've only seen two blades of grass in the skimmer and I think it was a "friend" who bothered to overstep. My kids know mom expects a grass free pool by now. :~}
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Aug 2010
    Dallas, TX
    4,052
    Re: am i infested?
    If you have a 2005, all you'll have is the Chlorine/pH block test thingy where you match colors.
    The 2006 you add R-0870 powder to your pool water, then add drops of R-0871 until the water is clear. Then you add 5 drops R-0003, then add R-0871 again until clear. If this is the kit you have, I will point you in the right direction for the detailed information.
    If you still believe you have a 2005, here's how:
    Add water to the chlorine side of the block, make water or bottom of water miniscus even with line near the top of the block.
    Add 5 drops R-0001 and agitate
    Add 5 drops R-0002 and agitate
    Match color of solution to the scale. This is your free chlorine (FC)
    Add 5 drops R-0003 and agitate
    Match color to scale, this is your total chlorine (TC)
    Subtract FC from TC to get CC (TC-FC=CC)
    May 2011
    50
    Re: am i infested?
    lemme check tonight on which one.. i do add the r-0870 power.. 2 droppers, and it instantly turns pink.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: am i infested?
    I believe the Taylor 2005 is a DPD test. That kit can only test up to 5 ppm (without dilution). You will really benefit for a FAS-DPD kit, especially when having problems. See: http://www.troublefreepool.com/pool-...kit_comparison
    CC= TC-FC (but only applicable below 5 ppm for the dpd test you have).
    Since you are below 5 you can run a OCLT :http://www.troublefreepool.com/pool-...rnight_fc_test
    edit: just saw RobbieH's post, some repeat info here, and since it sounds like you have a FAS-DPD test, doing an OCLT should be easy.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: am i infested?
    Quote Originally Posted by cybernation
    If you have powder, it's a K-2006. Robbie just posted how to use a K-2005 to get CC but I believe you have a K-2006 because you mention powder.
    Fill the sample to 10ml.
    Add 1heaping or two scoops of the R-0870 DPD powder (it only needs to turn pink, if one scoop does it then don't bother with the second scoop). Swirl.
    Then use R-0871 reagent by drop and count till it turns clear. For the 10ml sample, each drop equals .5ppm. This result is your Free Chlorine (FC)
    THEN... add 5 drops of R-0003. If the solution turns pink again, you have combined chlorine.
    Then add R-0871 drop by drop. Again, each drop equals .5ppm. Count these drops till the solution turns clear again. Add the number of drops added here to the number of drops you used before adding R-0003 and total. This is your Total Chlorine (TC).
    Then compute: TC - FC = CC (combined chlorine).
    May 2011
    50
    Re: am i infested?
    cool will do that frogabog....
    i can't believe your kids go swimming in 54f water... my wife and i are cold at 24c, and we have never had our water over 29 c.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: am i infested?
    LOL, it's really only that cold when we fill or in early spring. But they will swim in it if I let them and their lips turn blue. 74 degrees in there yesterday. They thought they were in a hot tub :~}
