Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: Just started conversion from Baquacil to Chlorine to SWG
    Jul 2011
    Port Byron, IL
    24
    Day 1
    Just started conversion last night, added about 6 gallons of bleach to pool; generated interesting clouds of mustard-yellow WOW!!!! Believe all I need to do at this time is to keep adding bleach to keep FC at 15ppm. Have purchased Taylor K-2006 test kit and tested for first time this morning. Only added 1 drop of R-0871 FAS-DPD Titrating Reagent to 10ml sample to get color change from pink to clear. I interpret that ppm FC level = 0.5ppm, is that correct? If I had to add 2 drops FC level would = 1ppm? So fo getting a reading of 15 ppm FC one would have to add 30 drops to 10ml sample? Did use Jason's pool calculator to come up with about 6 gallons of bleach to get to 15ppm FC. Also added another 6 gallons of bleach this morning and am off to store to buy more... Photos from this morning below!
    Many thanks for any help - Barb
    Barb C.
    IG 20K - vinyl liner DE Pentair FNS Plusfilter
    Aug 2010
    Dallas, TX
    4,052
    Re: Just started conversion from Baquacil to Chlorine to SWG
    That is correct, that would be .5. If you believe your FC is very high, you might have to add 2 scoops of the powder before adding the drops.
    Anyway, your math is correct.
    Jul 2011
    Port Byron, IL
    24
    Thanks RobbieH!
    Believe I want high FC during conversion from Baquacil to chlorine. But will try adding 2 scoops next time. Just real new to all this and very thankful to TFP and all the great members for the helpful posts. Am sure I will post many more questions during this conversion....
    Barb C.
    Aug 2010
    Dallas, TX
    4,052
    only add 2 if you are pretty certain it is high. FC is going to drop fast during the conversion, so I believe your numbers are correct.
    Jul 2011
    Port Byron, IL
    24
    First 24 hrs of pool conversion under my belt! Have added 14 bottles (182 oz each) since start last night. Have another 31 bottles ready to go. Seems to be working, had funky orange stuff floating on top of my green, gray pool water this afternoon. Old socks I put over skimmer baskets were also full of orange stuff. Just need patience now...
    Barb C.
    Jul 2011
    Port Byron, IL
    24
    Morning of Day 3 and things are looking up. Had overcast day yesterday (Day 2), added 4 (182oz) bottles bleach early am, added another 4 bottles at 3 pm and 9 pm. Pics to follow.
    Took day off from work since it is my b-day and husband is off also. Will spend day vacuuming and adding bleach! Have great hopes of major progress today.
    Should I run a full test? Am just testing FC at this time.
    Barb C.
    Jul 2011
    Port Byron, IL
    24
    Pic from Day 2!
    Barb C.
    Jul 2011
    Port Byron, IL
    24
    Believe I can see 2nd step of stairs!!!!!
    Barb C.
    Jul 2011
    Port Byron, IL
    24
    Day 3 Test Results:
    FC = 12ppm
    CC = 4.5 ppm
    PH = 7.8
    Didn't run complete test, thought that was premature.
    What's next step?
    Check pool calculator and add enough bleach to get to 15ppm?
    Should I worry about other tests?
    Husband cleaned filter last night!!!! YEAH! Look at all that yuck he cleaned out.
    Thanks for all your replies!
    Barb C.
    Samantha_in_AL's Avatar
    Apr 2010
    Altoona, AL
    242
    It looks like you are making great progress. The overcast day (day 2) was probably a bonus! Keep up the good work and keep the pictures coming!
    AG 18' X 52" Round Pacifica Pool w/ Metal Diamond Unibead Liner. Installed in March 2007.
    2.5 HP Baquapure 2 Speed Pump, 200 GPM Waterway ProClean Cartridge Filter System.
    Former Baquacil user
    Converted to BBB in Fall of 2009 - Now I have a truly trouble free pool!
    Jul 2011
    Port Byron, IL
    24
    Morning of Day 5 of conversion:
    Pool has been vacuumed and filter cleaned.
    Test results from this morning.
    FC = 9
    CC = 2
    PH = 7.5
    TA = 260
    CH = 390
    CYA = 0
    Should I add baking soda now or wait until conversion completed? When do I add cya?
    Added another jug (182 oz) bleach.
    Thanks for all your help - Barb
    Barb C.
    30,419
    fireflies,
    Are you reading the article on how to convert in Pool School?
    Jul 2011
    Port Byron, IL
    24
    Dave,
    Thanks for reminder... Read article again!
    Should I have waited with cleaning filter? Well to late now. Believe it has helped since it helps with pressure.
    Guess I'll keep adding bleach until we pass OCLT and 0.5ppm or less CC for 2 days.
    Thanks
    Barb C.
    30,419
    Yes sir!! Keep it a shock value.
    Don't worry about the filter for now. It can be corrected later if you have some residual stuff in there. It will manifest itself by your inability to pass the OCLT.
    Once your water gets crystal clear (How does it look?), you should be able to get passed the OCLT a day or so after that.
    Lingering chlorine consumption for more than a couple of days might indicate the need to re-clean the filter. Cross that bridge when you come to it.
    Jul 2011
    Port Byron, IL
    24
    Thanks so much for quick reply, Dave.
    Water looks pretty clear, pics below. However there are stains on vinyl liner, believe this is residue from major algae attacks during baquacil use. Will have to deal with those once conversion is completed and SWG installed.
    Plan on testing water later on tonight for FC. Then add bleach to boost to 15 ppm and test again tomorrow morning. Pool does get direct sun from 11 AM to sunset.
    Cheers - Barb
    Barb C.
    If the stains are from algae, they should fade and slowly vanish during the conversion process.
    Jul 2011
    Port Byron, IL
    24
    Thanks Jason,
    Will keep working on conversion process - get the SWG up and running and then tackle the stains with Vitamin C and trichlor tablets tests.
    Stains have faded quite a bit since we started conversion.
    Thanks - Barb
    Barb C.
    Jul 2011
    Port Byron, IL
    24
    Sorry haven't kept up with posting our progress so this will be a bit longer...
    Yesterday (Day 6) morning 7 AM we successfully passed stage 1 of OCLT, lost only 1 ppm of FC
    FC = 14
    CC = 1.5
    TA = 275
    CH = 400
    no ph test done due to high FC and no CYA test since I had no added any CYA ever.
    Read pool school again and decided it was time to add CYA, added whole container, 4 lb. of Walmart brand through skimmers as directed on container, I know should have done the sock thing! According to pool calculator this was correct amount to bring CYA up to 30. Have not backwashed since I added CYA, container stated to wait 48 hrs.
    Tested water again at 10 PM last night, no FC - added 3 bottles (182 oz) of Walmart brand bleach to raise FC back to 15.
    Test result this morning 7 AM (Day 7 of conversion)
    FC = 15
    CC = 1
    TA = 225
    CH = 300
    CYA - black dot never disappeared , has only been 24 hrs since I added CYA.
    no ph test, FC to high hope to be able to test sometime this afternoon when FC lower. Should have tested last night when no FC.
    I know CC needs to be 0.5 for 2 days before we pass OCLT.
    Should I worry about high TA at this point? We want to install SWG as soon as possible, already have SWG. Should we adjust levels to SWG goals before we add salt?
    Water looks very pretty, never looked so clean and clear!!!!! But we have gray stains on liner, and some orange-brown stains in deep end. Hope this is residue from algae problems when using baquacil.
    Do I keep FC at shock level until we pass OCLT? What after we pass?
    Thank you all for your help! This forum is awesome, would have never gotten to this point without the help of you folks.
    Cheers - Barb C
    Barb C.
    Jul 2011
    Port Byron, IL
    24
    Just tested again Day 7 12:30 pm
    FC = 7
    ph = 7.3
    Do I need to raise ph?
    Thanks
    Barb C.
  20. Back To Top    #20
    Sep 2009
    Greentown, IN
    914
    Congrats on your conversion! Sounds like your enjoying some clear water
    Yes, Keep your fc level up until you pass the oclt. Then you can let the level fall to what your range levels should be for your pool cya. Anything under shock level is safe for swimming once you've passed the oclt.
    Cya can take up to a week to show up on your test. I try not to backwash for a week after adding any cya so none takes a chance of getting washed out. You may find you have to backwash before that if you still have any remaining stuff being caught up in your filter.
    Looks like your ph is low and your ta is high....
    If you're using an swg it will tend to raise your ph over time, which you will then want to lower again to bring your ta down until you reach the desired level. You can also aerate your pool to help bring the ph up faster.
    I would go ahead and set up the swg and work the ta down over time. Once people are in splashing and the swg is up and running it will slowly work it's way to the range you're looking for.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
