Thread: installing pump for chlorine and pump for acid
    Oct 2010
    Houston, TX
    152
    Was thinking of automating my spa by installing separate pumps for bleach and muriatic acid. Both of these would be added to the return line after the heater I'm assuming. Now, does it matter which order they are put in, and do they have to be a certain distance apart?
    15k gunite pool. Intelliflo VF. Autopilot SWG.
    2k separate spa with waterfall (ie: pain in the rear maintaining a separate body of water). 2HP Hayward Tristar pump.
    22,544
    Re: installing pump for chlorine and pump for acid
    There has been some discussion about that and it's best if you don't inject them at the same time. However, if you're injecting them over several hours you're most likely not adding enough of either to cause a problem. I would however, separate the injection points as far apart as I could if you want to inject them at the same time.
