Thread: How to measure DE without a DE-specific scoop or coffee can
    Jul 2011
    Bedford, NH
    67
    I have a Hayward-Perflex DE filter. Last week I drained the filter and refilled the DE, but I wanted to make sure I did it right.
    Filter says it needs 4lbs, I've read you should refill with 80% of that, or 3.2lbs. What I did was I took an old plastic cup (think gas station big gulp) and filled it to the top with DE. Then I placed it on a postal scale I had, and it read "9oz". 3.2lbs is 51.2oz, so I divided that by 9, which came out to roughly 5.5 of those big gulps. That's what I put into the filter.
    Did I do this right?
    I'm battling some cloudy water as a result of terrible chemical balance (I'm new here and making progress using BBB), but wanted to make sure my DE regeneration wasn't hindering my efforts.
    18' round above ground, vinyl liner, 48" deep (flat), Confer Step1 steps. Approximately 7600 gallons. Waterways/Proline FC075 cartridge filter. 75GPM (71 minute complete cycle), 75 sq ft filtration area.
    22,553
    Re: How to measure DE without a DE-specific scoop or coffee
    Yes, weighing it is the best way. As long as you're close it'll be fine.
    Assuming that the 9 oz is after you subtracted the weight of the empty cup you should be fine.
    Jul 2011
    Bedford, NH
    67
    Quote Originally Posted by charlie_nj
    Yep...tared the scale out with the empty cup. Thanks all!
