Results 1 to 15 of 15
Thread: cheapo cover advice
    cheapo cover advice
    Just talked to the pool builder today -- the chemicals are all balanced, plaster's all brushed, and he says its time to close for the winter. We're waiting until next season to get the LoopLoc -- mostly because our budget was blown with the excavation -- so we just need something cheap to get us through the rest of this winter. PB suggested just tarp and cinder blocks...the only tarp large enough to cover the pool that I could find (at least on short notice) is only 5 mil thick. Is this thick enough to withstand a Virginia winter (we can have anywhere from half an inch to a foot and a half of snow, depending on the winter). I'm mostly concerned about my 40-pound dog decided to try to walk across it...would/should it hold that weight if securely anchored? I asked PB about leaving it uncovered, but he's afraid it would ruin the plaster (3M). Any insights or ideas? THanks
    (I should add that PB will be opening and preparing pool in spring as well, part of the purchase, so I really don't care a whole lot about how much algae and junk he has to fight in the process!)
    inground gunite, 18x38 freeform, 3'-9' w/ diving; 3M caymen green/blue blend; Pentair 2HP whisperflo; + aux pump for water feature; SWG; Rheem heat pump; Polaris 380; Pentair TR 100 sand filter; silverlake flagstone coping/broom finish concrete deck; NPTG Aztec cobalt tile; 18" bond beam wall with water feature
    I don't know if 5 mil plastic will work or not, thought I suspect that it might last one winter. But do not use cinder blocks! What ever you use to hold the cover down is sure to go into the pool at some point and I would rather not see a cinder block in the pool.
    Generally the cover is placed directly on the surface of the water and the water holds it up. You can't anchor a cheap cover the way a Lop-loc cover is anchored, it needs to sit down on the water. It wouldn't be a great idea for a dog to try and walk on it as it will just sink down under their paws and then probably get ripped by their claws.
    You can get regular pool covers, along with water bags to hold them down, very quickly via the Internet. A couple of vendors have covers for next day delivery in various sizes.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: cheapo cover advice
    Your dog will go through anything but a Loop-Loc style cover. If you try to use a tarp, it will get covered with water, presenting a drowning hazard, and anything that gets on top will pull the blocks into the pool. Solid covers have to be pumped off for safety. Imagine trying to free yourself from a tarp wrapped around you under water. There are mesh covers that are in the "few hundred dollar" range, but they can be tricky to get to hold in high wind at first.
    Personally, I'd suck it up and go for the safety cover if you can. You'll sleep better. No worries about fishing a dead dog out of the cover, or worse yet a neighbor kid. I bought mine and installed it in a few evenings at a total cost of about $1400, which included a hammer drill and bit.
    98xc600's Avatar
    Jul 2007
    Southern MN
    148
    You can spend a few dollars on a cheap cover now and wait to buy the right cover next year, but what's that cover going to cost next year? I'm sure it'll cost more next year, plus now you have to add the price of the cheep cover you wasted money on this year. hopefully you don't need to figure in the price of a lost pet or a lost life. Just my way of thinking??
    16' by 32' cornelius AG vinyl liner, 6' deep end, 14500 gal.
    Hayward 250 Lb sand filter
    Hayward 40 GPM pump
    2-2' by 20' sun grabber solar heater.
    4 gal Liquidator. BBB
    Mantua, NJ
    80
    Quote Originally Posted by vapool
    Are you sure the PB will be coming back after opening to fight the algae? Usually they just install hardware, remove cover and dump a startup chemical kit. The vacuum, cleanup is on you.
    Joe
    21k IG vinyl, 300 lb. sand filter, 1hp pump, Polaris 280 cleaner, 3/4hp booster pump, 240sq ft Fafco solar, Liquidator
    Thanks everyone for all of your advice. I'm really not sure what to do...as far as getting the Loop-Loc now, it's more a matter of time than $$ since it takes about 3 weeks or so to order (or so I've been told). JasonLion -- I feel more comfortable knowing that the cover will rest on the water rather than be flush with the deck, since my dog would not jump down onto a tarp (at least I don't think so, though I don't want to give her too much credit for having a brain!). Still, I think I'd be much more comfortable leaving the pool uncovered altogether.... PB is coming today, so I'll talk with him some more. Thanks again
    Guest
    One of my dogs almost drowned because she thought she could walk on the solar cover. even though it was almost a foot below the deck floating on the surface of the water. I am glad that I was with her and was able to fish her out as soon as she fell in. I stopped using a solar cover after that. I'd rather have a cold pool than a dead best friend!
    If you are closing it up get the loop loc!
    Dec 2007
    Central New York
    504
    Quote Originally Posted by waterbear
    I never thought my dog would step on the solar cover either. But something caught her eye and out she went onto the cover. I was right there also but had a heck of a time getting her out. She won't even go near the side of the pool now.
    So vapool, what did you finally do? If you didn't get a LoopLoc for this winter, get one for next winter. They are worth the piece of mind; even if you have a fence.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    Guest
    Quote Originally Posted by Hotrod30
    i have a looploc but i dont see really how it helps safty wise. if enough weight ( i threw a 40 pound bag of sand on the cover) and it filled up with a foot of water. i dont see how really thats gunna stop somebody from drowning when you cant really get up since the cover is so loose., and those guys put these things on TIGHT. is somthing not right with mine, or is that normal and i need to get a safty net now too.
    Dec 2007
    Central New York
    504
    I know when the dog went in the solar cover kind of wrapped right around her. The more the dog struggled the worse it was. I had to go in after her but luckily it was in the shallow end.
    With the LoopLoc it won't wrap around you. Yes, it will sink into the water some with a persons weight; but I would think an adult could crawl off it. A young child would at least be held up and not covered by the cover.
    I never believed the elephant picture.
    Hotrod30
    Pentair VF3050 pump
    Guest
    My dog went under the cover! I had to jump in and push the cover back. She almost drowned!
    ivyleager's Avatar
    Sep 2007
    Raleigh-Durham,NC
    489
    Quote Originally Posted by Rollin Thunder
    My rescue 45 lb English Springer Spaniel on her first day in the yard was so excited that she saw us going into the house and just had to take the shortest route back to the house. That took her directly over the loop-lock mesh cover over our IG pool. Sure, her feet got wet and she sank a bit into the water, but it held her weight enough for her to comfortably walk diagonally across a 18x36 pool.
    The cost of a loop-lock cover: $1500
    The look on my dog's face: PRICELESS!!!!
    Either get the safety cover, or don't use anything. JMHO.
    CaryB
    CaryB
    36 x 18 IG vinyl, 25K, 1 HP pump, sand filter
    1 skimmer, 2 returns, no main drain
    Old school: PoolSolutions test kit
    Sorry for not posting back until now, but just wanted to update that we DID get the Loop-Loc, and it arrived just a week or two later (much faster than we thought). Am SO glad we went with it.... Until it was installed I wouldn't let my dog out unless I was right there with her to chase her away from the pool. First week that the Loop-Loc was in place she marched right out into the middle of it....and pooped. The cover sinks a little with her weight, kinda like a trampoline, but not enough to go deep into the water. I, meanwhile, have not yet gathered up the courage to go out and retrienve the poop (fortunately it's frozen)!
    SW Indiana
    9,199
    Loop-Loc (or similar safety cover)= Peace of mind in my book.
    When the cover goes on, you no longer have to worry about the pool. The best part is you saved whatever money and time you'd have spent on a cheap cover.
    Late to the game here....
    We have 2 labs. 75# and 65#. They see the looploc cover as their own personal play area. Had really great warm weather up until yesterday and they go out and lay down on it to get cooled off. When they are side by side in the center it dips down about 9" into the water.
    Also sent our 11 yr old out on it (we were standing by) to pick up the hundred or so rocks that they carried out on it. No problems!
    Should be opening 5/10. Want two weeks of sun to warm it before I hit it with heat for Memorial day!
    30,000 gallon vinyl / Starite pump, Sys 2 cartridge, Max-E-Therm 333k heater / Bioguard SWG
