Thread: Intex 2500 pump set up ideas????????
    I have a 15/48 intex pool, I have the 2500 pump with the swg. I am about to add a thru wall skimmer and I have a extra 2500 pump should I run a separate pump for my thru wall skimmer or link it with my pump that runs my swg and just run one pump. Any ideas would be great.
    Re: Intex 2500 pump set up ideas????????
    You could make it work either way. The ones I have seen just use one pump. The original outlet can be used for vacuuming. If you decide to go with two pumps, how do you plan to do the return; over the wall, cut a new hole or something else?
    18'x48" Intex metal frame pool, 1600 Intex sand filer/pump combo, Intex SWCG.
    I would prob cut a new hole.
