Thread: Cloudy water coming out of my returns
    My returns are returning cloudy water. The water in the pool looks pretty clear, but I am not sure why the returns are returning such cloudy water. I have a 40K gallon pool and have a Pentair SNF 60 filter. Do I need to clean the filter or back wash it or could it be something else? I just cleaned the filter and put new DE in about 5 weeks ago.
    I appreciate your help.
    Aug 2010
    Boston, MA
    176
    Re: Cloudy water coming out of my returns
    One possibility that comes to mind is that the cloudiness could be DE getting into the return flow via a damaged filter grid. Possibly something happened during the cleaning, for instance. If none of the experts has any better ideas, you might consider opening up the filter and taking a look for possible damage.
    20k gallon IGP
    Plaster over gunite
    3/4 hp Hayward pump
    Purex Triton DE filter
    TF100 test kit w/ speedstir
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Do you by chance have a SWCG? The bubbles in the water can make the water look dirty when it comes out of the returns.
    Samantha_in_AL's Avatar
    Apr 2010
    Altoona, AL
    242
    Another possibility is that you could have a pin hole leak in the suction side of your plumbing which makes tiny air bubbles. This could explain why the water looks cloudy when it comes out of the returns, but the pool looks clear.
    AG 18' X 52" Round Pacifica Pool w/ Metal Diamond Unibead Liner. Installed in March 2007.
    2.5 HP Baquapure 2 Speed Pump, 200 GPM Waterway ProClean Cartridge Filter System.
    Former Baquacil user
    Converted to BBB in Fall of 2009 - Now I have a truly trouble free pool!
    I do have a SWCG. The water looks cloudy coming out of the returns and I put it to return only water to the spa and the water in the spa became cloudy as well.
    SW Indiana
    9,199
    Quote Originally Posted by ccp
    Turn the SWCG off and see if the water clears after a few minutes.
