Thread: jerry rig leg supports
    Jul 2011
    Southern WV
    11
    I'm new to this site & a 1st time pool owner that's having some problems...check my other topic for photos...
    Has anyone ever "jerry rigged" a AG pool leg support(s) and its worked?? Would it be possible to rigged a wooden support brace using 2X4's 2X6's landscaping timbers etc?~~ it will only be temporary
    Something like the side supports on oval pools...
    20x48 Pro Series Metal Frame
    by Polypool/ Summer Escapes
    8,800-gals
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Re: jerry rig leg supports
    Careful man, your dealing with how much weight? 60 or 70 thousand pounds of water?
    I don't think the concept of "jerry-rigging" and "pool legs" go very well together, ultimately you need to determine the source of the problem and rectify properly.
    I appreciate the limited water perspective but if your "jerry-rigged" pool suffers a catastrophic failure you could be endangering peoples lives, and/or property.
    Will children be using this pool?
    Jul 2011
    Southern WV
    11
    Quote Originally Posted by cramar
    Thanks for your response....
    I live on a 40-acre farm in the middle of nowhere. No children, pets, neighbors or structures would be damaged IF pool were to collapse. The only damage might be a hedgerow.
    Sorry I'm limited on time at the moment......Please check my other thread "Newbie needs help ASAP" for more details & photos..
    8,800-gals
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    There's something to be said for the way an Intex pool flexes as swimmers swim. I would not brace the legs over attempting to pack hard dirt and sand around the pool and trying to lift the leg into place. Even if you can't get it perfect, it would be better.
    I would not want to go through the side of a collapsed pool personally. At minimum one would get scratched up, but likely more severe injury would occur.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    I did check out your other posts, I'm certainly no expert on the matter but I just don't think your gonna find alot of support for some kind of temporary leg bracing to aid in withstanding that much weight/force. Not to mention the added force exerted when jumping in or swimming around.
    The legs on the ovals are a bracing system and I really can't see replicating that on your model of pool.
    If that thing failed and you were in it, one of those pavers at the base of you pool could slam you in the head as you both get washed out. Personally I wouldn't trivialize being in a pool it if collapsed.
    I appreciate your dilemma, but it really needs to be fixed properly, in my opinion. Does the nearest town have a business, or fire dept, that will fill the pool for a fee?
