Thread: buying a house
    buying a house
    I am in the process of buying a distressed property. It has a 18 x 48 inground pool that was deep enough to have a diving board built in 2002 - 2004. It had a vinyl liner with at least a 3ft concrete apron around it. I could not tell how the pool was constructed behind the liner. The liner is shot as it is ripped in numorous places. The pool also currently has none to little water in it. It has a sand filter and an existing pump.
    I am about to go into the due deligence period of the purchase so time for inspections. My question who is the best people to call to have the pool looked at and given an idea of the condition and cost to get it up and running?
    I want an idea of the cost because one of the reasons we want the house is the present of the pool but we do not want it to be a money pit when we could have bought another house and built our own pool.
    Aug 2010
    Dallas, TX
    4,052
    Re: buying a house
    Post your location so someone can recommend a pool company if possible. Your home inspector might be able to recommend a pool inspector also. Most inspectors only do a basic inspection on pool equipment and have no way to give estimates for repairs. Your agent might be able to provide a list to you. In Texas, they can't recommend a specific person or company, don't know about your state.
    Repairing a pool is FAR cheaper than building a new one!
    Re: buying a house
    The house is in West Atlanta Georgia.
    Mar 2010
    South OC, California
    67
    Re: buying a house
    Since it sounds like the pool needs work, you are better off having some pool contractors come to take a look at the pool and give a repair estimate. A pool inspection will only tell you what's wrong, but wont cover the actual cost to fix it.
    32' x 15', 25k gallon gunite IG pool, California Quartz plaster in Tahoe color
    Pentair equip (Intelliflow VS+AU pump, DE filter, IC40 SWG)
    Spa wall removed to make "seating" area
