Thread: Question about adding bleach after a soak
    I have an Arctic Spas 1400 liter (370 gallons or so) hot tub. I use the 3 step bromine method.
    What I've been doing is adding a bit of bleach to the tub after every time I use it. Normally me and my girlfriend are in it every night for about 15 minutes or so. I usually add a bit of bleach right afterwards. Then about once a week I'll add quite a bit of bleach to bring it up to 15 ppm.
    Is this what I should be doing, or should I only add bleach after a soak if the bromine levels are quite low?
    Intex AG metal frame 4440 gal. Intex 2500 gal filter pump. Intex SWCG with copper producer.
    Jul 2011
    Central Califorina
    208
    Re: Question about adding bleach after a soak
    That's pretty much the same routine I use to do.
    How are you testing?
    On my weekly shock I would always use spa perfect enzymes and sea clear. Alway got more waste out of the tub that way.
    If you use the tub at least 3 to 4 times a week you should consider dichlor/bleach. I am much happier with it. Water smells better and I don't get near as much waste when I oxidize.
    3500 gallon 14x42 Intex Ultra Frame
    1/2 HP Intex 1600 sand filter/pump - Intex SWCG
    Two 4x20 Fafco solar panels.
    Taylor K-2006
    Marquis spirit hot tub - Grill Dome ceramic grill/smoker
