Thread: how is my pool.
    how is my pool.
    I am new to the pool scene... about a month now. I have been useing the BBB method. Great site, I am learning a lot. I have a crystal clear pool. My wife seems to think it is slimy here or there. But... I read some threads of the slimy issue. So i vac'd the pool to day and tested for CC and was zero. So here is my numbers...
    FC - 5.5 i added to much chlorine before testing. Filter ran about an hour before testing
    CC - 0
    CYA - 30
    TA - 140
    PH - 7.8
    CH - 60
    Temp about 84 deg. Should I try and lower my TA? or anything else need adjusting? Oh I am useing liquid chlorine 12.5% from pool store.
    Everyday is like vacation!!!
    24' x 4' pool, BBB method, the pool calculator
    Aug 2010
    Dallas, TX
    4,052
    Re: how is my pool.
    You could lower your pH with muriatic acid. You don't have to go far, use poolcalculator.com to determine what will put you at about 7.5. I wouldn't say it's necessary though. Generally though, everything looks good to me!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: how is my pool.
    Why don't you tell us? You live with it.
    I used to see it all the time at work at my old job.
    "I want to know if my AC is working."
    "Does it blow cold?"
    "Yes"
    "Then it's working."
    When in doubt, more chlorine, more brushing.
    I never even look at that chart in Pool School; I use Pool Calculator to check CSI, so I just use the recommendations there, and tend to maintain FC near the upper end of the range for a little insurance.
