Thread: Skimmer Quality and Performance ?
    Jun 2011
    Cape Girardeau, Mo
    125
    I am getting ready to install an in wall skimmer in my intex pool. Quality and performance wise would you go with a Pentair or Hayward or are they both the same the Pentair is cheaper.
    Steve Frakes
    15' X 48'' Intex Metal Frame
    Intex Sand Filter 16'' 2650 GPH
    Taylor K-2006 Test Kit
    BBB and Borated
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Skimmer Quality and Performance ?
    IMHO - they're all the same. You want one that you can readily replace the weir because that's the biggest issue with skimmer performance. (have you thought about getting an 'aquadoor' , it's a helpful feature for the winter but make sure it matches up with your screw holes. )
    Luv& Luk
    -Ted
    Jun 2011
    Cape Girardeau, Mo
    125
    Is the Aquadoor the cover that fits over a skimmer for winter if so yes i have looked at them and plan on getting one before winter. I guess i will go with the Pentair there replacement weirs should be easy to find.
    Steve Frakes
    BBB and Borated
    May 2011
    23
    I find Pentair weirs (the circular tube-shaped ones) WAY better than Hayward's door-type weirs. Hayward's weirs break too easily and often the foam stuff that they use in it eventually disintegrates into nothingness, rendering your weir useless.
    Florida Pool Service Guy
    15k Kidney Diamond Brite
    Hayward C-1200 Cartridge Filter
    Sta-Rite Dura-Glass 1.5hp Pump
    Pentair Rainbow 320 Chlorinator
    Heliocol Solar Panels
