Thread: Testing Chlorine stength
    Jun 2011
    NW Florida
    57
    I use NaOCl 10.5% and HCL 31.45%. I just recently added bleach a couple of times, and got much less than the expected change in FC, and CC remained steady. Can someone recommend a safe and simple titration or other method to test the NaOCl strength? It's been awhile since I had chemistry. I have a K-2006 test kit and no other means to measure pH.
    Mike
    Commercial,100 K, Liquid chlorine, Indoor, Heated to 86 with Jandy Lite 2 gas heater, High-Rate Sand Triton TR-100 filters (3), 7.5 HP pump motor, IG, Plaster.
    Jesus is my Lifeguard!
    Re: Testing Chlorine stength
    There is a procedure for doing this described in this topic and that topic also lists the specialty Taylor kits you can use to get more precise results.
