Thread: ta ppm vs. ph ppm
    ta ppm vs. ph ppm
    Can someone please tell me how much ta lowers when you add acid to lower ph. If i add 30 oz of acid to lower my ph,how much will that lower my ta. Is there any formula for this. I searched,but couldn't find any answer. THANKS for any help on this.
    20X40 IG,33,000 GAL,VINYL LINER,1 HP PUMP,HAYWARD SAND FILTER,CAMDEN,S.C.
    Jun 2011
    Northeast Ohio USA
    178
    Re: ta ppm vs. ph ppm
    Pool calculator will tell that and more http://www.poolcalculator.com/
    Looks like TA will drop 3.6 if you use the 20 Baume Muratic (Liquid) Acid given your scenario.
    Vinyl In-Ground (vinyl) - about 21600 gallons (18x32 Grecian)
    Hayward DE (model 7220?) filter with Multiport valve
    Challenger Hi Flo Pump (3/4 HP)
    Intex SWG
    leaky/non-functioning Raypak Versa Natural Gas Heater *removed*
    Look at the effects of adding chemicals, right near the bottom on the Pool Calculator.
    I really do thank you for helping me. I didn't realize the effects were at the bottom of calculator. I'm a dummy,but i'm trying to learn.
