Thread: ? about muriatic acid
    Does muriatic acid stay like cyanuric acid does? Or does it break down?
    11000 gal L shaped gunite pool with and aggragate plaster
    Pentair cartridge filtration with 1.5 hp pump
    only have 3 returns and one dedicated vacuum line
    manifold to pump is three valve
    22,553
    Re: ? about muriatic acid
    It breaks down.
    Mar 2007
    San Rafael, CA USA
    12,082
    More specifically, it lowers the pH and TA and increases chloride (salt). Generally speaking, the amount of salt buildup from Muriatic Acid is far smaller than than from chlorine, but even that is a rather slow buildup since salt is rather innocuous except at much higher levels. With bleach or chlorinating liquid, at 2 ppm FC per day chlorine usage the salt increases by around 100 ppm per month if there is no water dilution.
