Thread: Reading CYA on TF-100 test kit
    Jul 2011
    N. Ga Mountains
    151
    My question may sound silly, however I need to be sure I am reading this correctly. When I fill the tube for the CYA test (using the TF-100 test kit) do I read the level where the black dot cannot seen at all or when it is hazy without an outline? It still looks grayish in the bottom but I cannot delineate the outline of the black dot, then my reading is 100. If I keep going until I absolutely cannot make out any darkness then it is 70. I am shocking my pool right now and am concerned that the cya is way too high. I don't know if I should continue shocking or start replacing water. I have a rather stubborn algae bloom and have been shocking since yesterday morning. I am using dichlor. I will switch to the household bleach but was using up what I already have. Thanks for your help.
    33 ft round x 52", vinyl
    Hayward 1.5 hp pump
    sta-rite 2.18ft ,200 lb sand filter
    24500 gal.
    Hayward Salt & Swim3
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Reading CYA on TF-100 test kit
    Here is a link to pictures from Taylor:http://www.taylortechnologies.com/Ch...P?ContentID=44
    Jun 2011
    Northeast Ohio USA
    178
    dichlor will also raise your CYA level even higher than it all ready is, making the shock job even more difficult. In my limited experience, I would advise to save the dichlor for when you need it and shock with straight bleach for now.
    Vinyl In-Ground (vinyl) - about 21600 gallons (18x32 Grecian)
    Hayward DE (model 7220?) filter with Multiport valve
    Challenger Hi Flo Pump (3/4 HP)
    Intex SWG
    leaky/non-functioning Raypak Versa Natural Gas Heater *removed*
    Jul 2011
    N. Ga Mountains
    151
    OK...I didn't realize I could switch mid-stream. Thanks for the help!
    Hayward 1.5 hp pump
    24500 gal.
