Results 1 to 7 of 7
Thread: Flexible Schedule 40 PVC Pipe
    Dec 2007
    Central New York
    504
    Flexible Schedule 40 PVC Pipe has a rating of 60 psi. Can it be used between the pump and the filter? I want to use 2 inch flex hose between the pump and the filter. I can't find the normal PVC clear hose in 2 inch, only in 1 1/2 inch and smaller sizes. Any suggestions. What do you use?
    I already bought the pump. It is a Pentair IntelliFlo VF3050 pump with 2 inch inlet and outlet. I plan to get a new filter with the 2 inch valve.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    Mar 2007
    Coastalish 'down easter'
    4,160
    Hey Hotrod, welcome to TFP (thanks for answering my frozen tub post )
    If I wanted to use flex, I'd get some 'Tigerflex' 2" pipe. Otherwise Id use rigid sch 40 2" pipe (I always use a 90 but 2 45's would reduce the head a little) Of course use unions on both ends, just in case... If you go with the flex pipe, make sure there is enough room so that it doesn't 'crimp' as that would obstruct the flow worse than a 90
    Plese let us know how the project progresses (we love to see pics) - Again, welcome here!!
    Luv& Luk
    -Ted
    30,414
    Hotrod,
    Flex will stand the pressure just fine. Over the years of reading the forums, it seems like flex installations cause a few more problems than ridgid PVC. I suspect that's because of semi-careless workmanship rather than any inherent problems with flex.
    Ridgid PVC with unions is probably the most permanent installation you can do but, as you would expect, the most time-consuming installation as well.
    I would not do it.
    Authorized IntelliFlo Installer
    divnkd101's Avatar
    Mar 2007
    Pearland, TX (Houston Suburb)
    587
    Quote Originally Posted by repair_guy
    I would not do it.
    Please provide reasoning behind your opinion.
    MIKE
    21K Inground Custom w/ Spa (Gunite/Plaster), SWCG, Hayward Northstar, Polaris 280, Hayward Color Logics, Jandy PS-8
    Dec 2007
    Central New York
    504
    I found this site today. They sell the Reinforced Clear PVC Tubing Polyester Braid in 10 foot lengths. Working pressure is 75 lbs at 70 deg. I think this is what I will go with.
    http://www.usplastic.com/catalog/produc ... 5Fid=25231
    Hotrod30
    Pentair VF3050 pump
    I used 2" flex PVC between my pump and filter and have had no trouble at all.
    21,000 gal Fiberglass (Indoor)
