Results 1 to 9 of 9
Thread: Worried and confused about bleach and shocking....
    Jul 2011
    Gordon, GA
    18
    My pool needs shocking. My test kit is on the way...
    It already has a a pretty strong chlorine smell. Won't adding all of this bleach make it worse? Will it be safe to swim in? I don't want to ruin all of our swim suits
    AG Intex 5300 gal (15x48)
    Intex SWG 700 gal/hr
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Worried and confused about bleach and shocking....
    The smell comes from CC (combined Chlorine) which is caused by having high organics (Algae) in pool. So that is an indication you need to shock. If you use Chlorine to shock, that is free chlorine (FC) and does not smell (though as it is killing organics it may smell due to CC, but that will go away once you have killed the organics). Have you read: http://www.troublefreepool.com/pool-...king_your_pool and the rest of Pool School?
    Most people around this forum agree that swimming up to the shock level for you pool (as calculated by the poolcalculator.com) is safe to swim.
    If your pools smells "like chlorine", you need to shock. A properly maintain chlorine pool should not smell.
    Jul 2011
    Gordon, GA
    18
    I have read and read for 4 or 5 days. I feel incredibly stupid. Everyone keeps asking everyone if they've read Pool School, etc. I have, and I'm still confused. I have never dealt with a pool ever....
    I just want it to be safe and clear.
    Thanks!
    WestSidePool's Avatar
    Cincinnati, OH
    424
    I would say your best bet while waiting for your test kit is to run a sample up to the pool store, so you get a general idea of where your numbers are at. They may not be 100% accurate, but at least you have a guideline to go by when adding chlorine/bleach to shock it.
    Also w/ having some numbers, the people on TFP will be able to help you understand what's going on with your water. Currently it's just a guessing game.
    Eric
    IG 17x33 Grecian - Vinyl Liner (21k gallons), Hayward Pro-Grid DE 4820 filter, Hayward Super Pump, CompuPool SWG CPSC36, TF-100 Test Kit
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by Valentine
    Thanks!
    Sorry about stressing the Pool School, but I read it many times (and still do). My guess is once you get your test kit, you will start absorbing more of the info. Without a kit, it is sort of like being blind and having a painting described to you, but not being able to see it.
    Jul 2011
    Gordon, GA
    18
    Sorry.....here is my thread from yesterday with my numbers from the pool store:
    http://www.troublefreepool.com/new-p...ts-t36609.html
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    You'll get there! I would keep all your posts in one thread for now (I would suggest the other one). This helps the forum understand the history and help you most efficiently.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Here's a simple explanation of what happens when your pool needs to be shocked and what happens when you shock it:
    Chlorine sanitizes the pool by breaking down contaminants. In the process of breaking these things down, the chlorine is used up. If the contaminant load is too high or the FC level is too low, the chlorine can't finish breaking down the contaminants. It is at this stage, when the chlorine is partially reacted with the contaminant, but not broken down, that you smell the "Chlorine Smell".
    At this stage, you need to add enough chlorine so it can finish the job. That is shocking. When it fully breaks down all the contaminants, the chlorine smell goes away and the filter will begin to remove the debris left over and you can return to normal chlorine levels.
    Jul 2011
    Gordon, GA
    18
    Thanks everyone!
