Thread: Spa owner in CA
    Spa owner in CA
    Hello everyone,
    I purchased a home two years ago with what I believe to be a 300 gallon in-ground Jacuzzi. I'm currently experiencing a problem with the natural gas heater, a Teledyne Laars/ Jandy XE EG400, and I have a feeling I will have to replace it.
    The label on the unit lists an input and output rating of 400,000 and 280,000 BTU's, respectively (see attached photo). While pricing new units, however, I notice only one BTU rating listed. Which one should I be looking to match? And, since the price on a given unit can differ as much as $1,000 depending on the BTU's, I'm wondering if I even need this many BTU's.
    Another thing I was wondering is if it's better to go with an electric spark ignitor over a gas pilot?
    Any help will be greatly appreciated,
    Mike
    24' Round,Vinyl, 13500 gal AG/Haywood 200S Filter/not sure of size or flow rate/TF100 Test Kit
    Jun 2011
    Northeast Ohio USA
    178
    Re: Spa owner in CA
    I would think the output it what you would care about.
    This link might be helpful http://www.classicpoolandspa.com/faqspa.html#spapart.
    Vinyl In-Ground (vinyl) - about 21600 gallons (18x32 Grecian)
    Hayward DE (model 7220?) filter with Multiport valve
    Challenger Hi Flo Pump (3/4 HP)
    Intex SWG
    leaky/non-functioning Raypak Versa Natural Gas Heater *removed*
