Thread: Steps floating
    Steps floating
    This is my first post, so not sure I am in the right forum.
    My problem is that I just put in a new AG pool (replaced old one that had ladder) with steps. I can't get the steps to keep from floating up at the bottom. Tried filling with water, no good. Instructions say sand, but not crazy about sand in the pool and how heavy that would make them when we take them out in the winter. I've seen a few things on here about jugs and PVS with concrete inside.
    This link on the forum shows pictures:
    what-to-use-to-hold-steps-down-inside-pool-t12647-20.html
    Does this seem to still be the best way to anchor them?
    Thanks for any help.
    Sherri
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    Re: Steps floating
    If the instructions call for sand, fill them with plain old sand filter sand and follow the instructions . I have two 50lb bags in our steps and no floating or sand in the pool
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,552
    Re: Steps floating
    ...............(you can remove the sand bags before you remove the steps from the pool).................................
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Steps floating
    You could try gravel.
    Ike
    Re: Steps floating
    I just installed my pool to deck steps this weekend. I wasn't crazy about using sand either, but I followed the instructions and added "10-15 lbs in each side". I then held the steps down and waited for the rest to fill with water, again per instructions. The steps still would not stay down on their own. I got in the pool and layed the steps down sideways so they were 100% under water. This helped all of the remaining air to escape. That did it. They are still very light in the water, right on the verge of floating, but they don't. There are a few factory holes in the part of the steps that they wanted me to fill with sand. Small holes, probably about 1/16" or so. I went under water and watched sandy colored water escaping from the holes. This annoyed me because i thought it was going to behave that way for a long time......a lot of sand in the steps now. It didn't. That stopped within 10 minutes.
    So, my advice would be to just do what the directions say. Good luck!
    24' dia. 52" Tall Costa Del Sol Plastic Resin by Trendium Pool Products
    250lb sand filter with 1.5 HP pump
    13,530 gallons
    Re: Steps floating
    My steps have a nice "tray" area at the bottom where I put 3x 4" PVC tubes (~1.5' long) filled with sand and topped off w/ water. It took a few minutes of adjusting and careful placement to not bump them into the liner, but they've been working great all season.
    (one end is capped and the other has a screw on top)
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
