Thread: Dichlor - cjioesajkjvioeskjskloiukgje
    Aug 2010
    St.Louis, MO
    26
    Here I am again, always trying to find the elusive Dichlor product in order to add CYA to the pool. My CYA current level should be at 23 (I still need to test) based on dichlor added about a week ago, and the chlorine is holding pretty good through the day, but wanted to have some more on-hand. I've searched the forums and I know that Sodium dichloro-s-triazinetirone and Sodium dichloroisocyanurate are the same thing. My last purchase was an AquaChem product that is no longer available. However the product I found today is 99% Sodium dichloroisocyanurate dihydrate.
    This is okay? Thanks once again.
    Intex above-ground, metal frame, vinyl liner, 12'x30", 1718 gallons, 1600 GHP Intex sand filter
    22,553
    Re: Dichlor - cjioesajkjvioeskjskloiukgje
    Yeah it's still Dichlor.
    Mar 2011
    Orlando, FL
    12
    If you are looking for CYA (stabilizer) most Walmarts and pool stores have it at 100% strength.
    Viking Pools Freeport 12' x 25' Fiberglass 6000 Gallon Screened - Hayward Pro-Grid Vertical D.E. Filter DE2420 Hayward Superpump 1HP - Zodiac Pacer Cleaner - Pool Pilot Digital - TF-100 test kit - Central Florida Thanks to TFP Pool School, SWCG and the Pool Calculator, taking care of the pool is easy!
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by GK
    Yep, you are correct and we like wallyworld CYA, too! But, the OP has a small pool and probably would only need about a cup or so per season. So they try to get the CYA along with the chlorine using dichlor.
    You're done SLAMing when:
    Aug 2010
    St.Louis, MO
    26
    Thanks everyone! I've never been able to find anything but cal-hypo products at Walmart around here. Straight CYA would be okay too, but haven't found that except at the pool store, which isn't always convenient. The last dichlor I found at K-Mart (which appears to be sold out for the season) so tonight I found it at Lowe's. I figured it was okay, but wasn't sure if "hydrate" at the end was significant.
