Results 1 to 17 of 17
Thread: Newbie needs help ASAP
    Jul 2011
    Southern WV
    11
    Any suggestions on bracing an above ground pool? Its a Pro Series 20X48 similar to Intex Ultra. Sand has started shifting and has broke several leg caps ..replacement caps are NOT IN STOCK! I'm not on public water and its taken several weeks to fill by spring feed water supply. Also its been so hot and dry in my location that water flow from springs has slowed so that draining and refilling is out of the question. After discovering the shifting I have not finish filling pool, it likes about 6 inches of being to level needed to operate skimmer. Greatly appreciate any ideas!
    20x48 Pro Series Metal Frame
    by Polypool/ Summer Escapes
    8,800-gals
    Re: Newbie needs help ASAP
    Can you describe the process you used to level the ground before setting up the pool?
    Jul 2011
    Southern WV
    11
    sloping ground was level by endloader, several tons of sand base was leveled, topped with a foam type material used to cushion pool liner.
    I've saw so many of the blue metal Intex models pools setup in my area and its unbelievable how "katy woped" out of level... it amazing they haven't collapsed.
    8,800-gals
    Jul 2011
    Southern WV
    11
    PS: pool legs are set on small block pavers, 6-legs on lower end have almost slid off pavers. Here, I know I should have used a larger paver. Have no kids no rough house in pool, just hoping to find a way to brace so we can finish out season without fear of collapsing. Will do setup different next year.
    8,800-gals
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    I'd re-seat that paver, and call it good.
    The leg does not look off plumb very much, if at all. Sounds like the leg was too far in, in the first place and the liner has pushed it out as water was added. I also would not worry much about the leg cap for now. It won't make or break your pool.
    Looks like a very level and well thought out build. Is your winter harsh? If not, you might be fine winterizing instead of tearing it down.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Jul 2011
    Southern WV
    11
    frogabog thanks for your response! Looks are deceiving, I checked water level this morning...there's now a 5-inch difference! It appears to be sinking down in the sand and hasn't move landscaping bricks. Yesterday Hubby drove a few metal fence post to prevent bricks from shifting out just in case. Our winters are far too harsh for winterizing. Searching a "temporary" bracing ideas, something to get us by 6-more weeks, until mid-September we'll drain and put up for the season. If weather permits, this fall or next spring plan to remove sand & re-level use decomposed granite also move landscaping/retaining wall bricks out about 12-inches. If in the event there were a collapse there's no danger of any damage to everything other than the pool itself.
    8,800-gals
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Darn. I actually didn't look close enough at the top of the pool. It's a little wobbly up there huh?
    Is the floor sinking? Or just the legs?
    How far out past the diameter of the pool was the surface leveled and packed? It looks like the pavers are kind of falling off the edge.
    Is the pool 5 inches higher on one side? Or is it variable around the pool?
    I guess I'm asking if the pool floor has sunk or if it's just the legs. Legs can be adjusted, with a little effort. The floor however, impossible w/o draining.
    Jul 2011
    Southern WV
    11
    Biggest problem...used too small of pavers which tipped because of sand, causing legs to slid off pavers which is making the 5-inch difference with water level...
    At this time there doesn't appear to be any problem with pool floor sinking.
    Base...sand was wet & tamped. 4ft level attached to a 10ft 2x4 was use to level sand. We didn't go out far enough pass pool diameter.
    Will post more photos!
    8,800-gals
    Jul 2011
    Southern WV
    11
    more pics!
    8,800-gals
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    OK, well wow...
    Looks like you have only a few choices to "try", and one that will work.
    It looks like the legs are the real issue, not the level of the sand/pad itself but without actually seeing the pool I can't say for sure.
    I would not recommend trying to raise the legs that slid off the pavers because water is heavy, and it's near impossible. However one member here described a home made jack made of 2x4's recently that could work if you could manage to pack enough material under those legs so they won't sink again. HARD to do this, likely will fail.
    I might try lowering the high side legs instead but I do not know if this would work either since the pad seems to be secure. It might create a "moat" of sorts around the outside of the pool which would be difficult to clean.
    The sure way to fix this is to drain, re-level (6-8" beyond the diameter of the pool), and refill. Is it the water cost or the time involved in this that has you looking for other alternatives?
    For whatever it's worth... the legs of my pool are on small wooden planks, not a whole lot bigger than those bricks however they are square rather than rectangle and only about 5/8" thick. They work fine, we left the pool up last winter and they remain secure. Wood seems more forgiving than bricks insofar as puncturing risk, you might consider another kind of paver for the feet, wider and perhaps thinner if you can find it. A larger foot pad would sink less and not topple quite as easy even if the sand shifted a bit.
    Others will have more insight I'm sure. We had to level 3 or 4 legs... H found them to be a few milimeters off level after filling and we scraped a tiny bit of material from under them to straighten it with him lifting and me scraping. It was not easy even to do that. Very heavy.
    Best of luck, however you decide to proceed.
    Jul 2011
    Southern WV
    11
    Thanks for all your suggestions!
    My water is Free.. its just in short supply due to near drought conditions in my location. Which creates a problem as far as draining & refilling and no one in my area delivers water anymore. I live in the country, no public water service and my water source is "spring" feed water which is pumped to the house the same as well water. We have a 1000-gal reservoir/spring house, and with the severe dry spell the water flow from springs is very slowed. It took almost 3-weeks to fill the pool to it present level...pumping only a few hundred gallons a day will take forever to refill 8,800 gal pool. I understand draining and correcting ground level is the best option. But as stated before, I'm so hoping to find a way to temporary brace/support those 6 pool legs until we tear it down for the season...about mid September.
    8,800-gals
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    OK, well here's the post where one member described a jack contraption and the process they used to adjust the legs.
    help-sinking-frame-t23845.html
    3w to fill a pool is a LONG time. Takes me 3 hours... I'd also be looking for alternate solutions.
    I had a similar issue this year when I put up my pool.
    I also used pavers that were too small and under estimated the distance they would "push" out. This resulted in legs that sunk even tough the pad was level.
    I used an automotive jack and rigged up a 2x6 that would straddle either side of the "T" bar. Lifted the feet that fell off, did my best to fill in and relocated the paver. It wasn't fun but it worked.
    Another thing, if you can get your hands on a temporary pool and do a water transfer (I had to do this too, yes i've set my pool up 3 times this year...). I failed to get my pool as level as it needed to be it was about 3 inches off. I setup a pool next to mine, used a sump pump to transfer the water, fixed the ground and then put the water back in.
    Intex 16' x 48" pro frame
    Intex 1600 GPH sand filter with integrated SWCG (copper unplugged)
    Through wall skimmer
    Hard plumbed
    Taylor K-2006C
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Quote Originally Posted by matt_e
    Smart guy you are there Matt... GOOD idea. Walmart will take anything back :~}
    Quote Originally Posted by frogabog
    A real smart guy would have leveled the ground right the first time
    Hard plumbed
    Taylor K-2006C
    Jul 2011
    Southern WV
    11
    Thanks for your response & suggestions!
    As for the temporary pool....that idea had crossed my mind too! One catch, property slopes no place level enough to set another pool without digging ground. I must admit after reading so many horror stories of AGP collapsing I'm paranoid as heck mine will fall to the same fate!
    8,800-gals
    Jul 2011
    Southern WV
    11
    THANKS A BUNCH!!
    8,800-gals
