Results 1 to 10 of 10
Thread: polaris 380 wheels don't turn
    Hi just installed a pool at my house and bought a polaris 380. Hooked it to pool and it ran just fine. Next day did the same thing but now polaris wheels dont roll. I turned single wheel and all wheels roll. I'm not very technical but can anybody tell me what to do before i carry it in to repair center. thanks
    Feb 2008
    Denton, TX
    5,061
    Re: polaris 380 wheels don't turn
    Welcome to TFP!
    Is your booster pump working?
    Have you checked the connections to make sure you aren't leaking water at any of them?
    Is the Polaris filter clean?
    Is there anything caught in the Polaris or clogging up the Polaris?
    I checked the booster pump. Its working well. Where is the polaris filter at and how do i take it apart?
    Filter screen is in the connection to the wall. There is a J hook latch to unhook.
    Before you undo that see if there is a lot of water exiting the pressure relief valve, which is there. I forget whether it is what you are unhooking or if it stays attached to the wall. It may have failed. When this happened to our 380, I found that when I covered that exit to stop that flow, the Polaris ran normally.
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Here is a link to the Polaris 380 manual: http://www.poolcenter.com/Polaris380_Manual.pdf The relief valve is screwed into the wall fitting - number 10 on the parts diagram. Polaris has had a lot of trouble with the relief valves leaking by too much, too easy. My new 280 did that and I called Polaris about it they sent a new relief valve and it leaked by also. Finally they told me to remove the valve and replace it with a plug. After that I didn't have any more problems.
    To tell if the valve is leaking turn on the booster pump and put your hand around the valve. If it is leaking by you will feel the water coming out. Remove the valve by taking the wall connection loose from the wall and unscrew the valve with a pair of channel locks. Take the valve to Lowes or Home depot and get a plug the same size. Screw the plug back into the hole left by the valve by hand then tighten about 1/4 turn with channel locks - don't over tighten or you can crack the wall fitting. Connect the fitting to the wall and turn on the booster pump. The cleaner should now run just fine. Then check the wheel RPM and adjust the speed if needed by using the flow restriction disks that came with the cleaner. Those instructions are in the manual.
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    hey i checked the valve and it is leaking. Gonna call polaris tommorow. Thanks a million!!
    Just go online and view the parts list, if you don't have it in your owners manual. You can order online from lots of places, or get it for slightly more at a local pool store and have it sooner.
    Polaris is brand new. Will i still have to pay for it?
    Brand new? Should be warranty work then, you're right.
    I had the same problem. After taking it all apart and checking the connections, I realized the band that goes around the gears of the wheels needed tightening. Simple fix!
